Integration of RTS blinders with Somfy Connectivity Kit & Homekit
Hello there!
I recently started going down the rabbithole with HA and im loving it!
ATM i have some basic automations running mostly with zigbee devices.
Next step on my ever growing (will it ever end?) want to/ have to bucket list for home automation are my blinders.
Sadly i couldn’t choose which type of motor(controller) get installed, so i’m stuck with Somfy RTS using Smoove 1 RTS switches.
I got me the Somfy Connectivity Kit as i read, that it can be integrated in HA via Overkiz and/or Homekit.
As of know i was able to integrate the kit as Homekit device in HA:
  • Downloaded Tahoma App
  • Connected via bluetooth to the SCK
  • Connected SCK to my network
  • Added Homekit device in HA
But i only see the kit/ device itself with the only entity button.somfy_sck_identify.
What am i missing, or how can i integrate my blinders? I also finished the configuration on the Tahoma App. After creating an account i was able to add a blinder:
  • Pressing “Prog” button on the Smoove Switch and search for device in the app
  • Testing blinder worked in Tahoma App. (Up-Down-Stop-My)
I was hoping, this way, when reintegrating the SCK as Homekit Device the blinder will appear as entity, but i still see only the one entity.
Did i miss something? I’d love to go w/o Overkiz as with SCK there is no local API support and cloud connection is needed.
Any hints much appreciated!
Best regardas and happy automating! :slight_smile:
Best is to create an issue on GitHub and add your diagnostics. Most likely your device is not implemented if there is no cover entity.
