Integration of Smartwares
I’m New here. At the moment I have an installation of Home Wizard which is not supported anymore. I’m using Smartware components with that. I want to change my installation to Home Assistant. Does anyone know if I can use the smartware components with Home assistant ? They work on 433,92 Mhz.
Regards,
Ronald
did you ever found out if smartwares HW works with home assistant?
Well, I’ve got an RFXCom, which should be able to communicate with the switches, only can’t get it running on HA. I tried to find out what protocol the switches use but have not been able to find it yet.
So is it correct that in order to use the Smartwares plugs and switches, you ALWAYS need the RFXcom?
