I operate some self-made environmental sensors via LorawAN and the things network.
I would like to have these values available in homematic so that they can be displayed.
I am currently mirroring the MQTT data from TTN in a local MQTT broker via nodered.
The data comes as json in a topic.
The data is already formatted accordingly via the TTN payload decoder .
That doesn’t seem to work
- platform: mqtt
topic: "v3/tinynode-v2@ttn/devices/+/up"
device: "{{ value_json['end_device_ids']['device_id'] }}"
json_attributes_template: >
{ "humidity": {{value_json['uplink_message']['decoded_payload']['h']}},
"temperature": {{value_json['uplink_message']['decoded_payload']['t']}},
"voltage": {{value_json['uplink_message']['decoded_payload']['v']}},
"pressure": {{value_json['uplink_message']['decoded_payload']['p']}},
Unfortunately I don’t know what to configure so that the topic is parsed dynamically (number of sensors can change) and the data processed accordingly.
I have read in MQTT Sensor - Home Assistant, unfortunately the examples always only have one sensor, I needed that dynamically.
Furthermore, I get several values in a topic (pressure, temperature, air humidity, voltage), is ‘json_attributes_template’ the right approach?
Thank you and best regards
Andreas
