Integration of Tuya/Smart Life Presence Detector HZ-PS01
Hi.
I want to use the Tuya / Smart Life Presence Detector HZ-PS01.
I can connect it to my SLZB-06 Zigbee to LAN adapter (coordinator mode) and add it as ZHA device. But there are no entities found.
Using the official Tuya intergration also does not work, because the Smart Life app does not support the SLZB-06 gateway.
Does anyone have an idea how to get this working without buying a Tuya Zigbee gateway?
Thanks,
Dirk
You will need a custom quirk
See here (also the place to ask)
Has anyone found the ZHA custom quirk for the HZ-PS01 model? Thanks
I bought the same devices and stuck without a solution :neutral_face:
Posting/hoping someone has found a way to get this to work?
HA hasn’t detected the device yet. How can I do it? I’m using ZHA.
