hello, I have a question regarding the ORVIBO integration, if it works for the security kit. is a hub to which several censors connect. I leave e llink of the product.ORVIBO SECURITY KIT INTRODUCTION - YouTube
Did you find some solution to this? (I’m from Argentina)
I like the prices of these devices. Are very cheeper.
Yo pude integrarlos con zigbee sin problemas
Hola Manuel, ¿pudiste integrar Sensores Inalámbricos Gynoid en Home Assistant?
I’m planning on getting this, apparently both the door and motion sensors work with ZHA and Zigbee2MQTT as per:
Will report if I find any issues
These devices do indeed work with ZHA, I haven’t tried Zigbee2MQTT.
The door/window sensors show up as an opening sensor in ZHA. There’s a caveat with the motion sensor though, one entity shows as “Vibration” while in reality it’s the motion sensor with a very low turn off delay. My understanding though is that the motion sensor does provide vibration detection for tampering, so it might be a matter of doing some reverse engineering.
