I like to share the kios api, maybe it’s helpful to someone, it is for me
I discover that Huawei has a kios api, you can easy use it in you configuration.yaml file.
(there is a small latency)
- Sign in to your huawei portal https://eu5.fusionsolar.huawei.com
- Click on the “Kiosk” button
- You should replace “replace_with_your_kios_id” in the script below with your own kios_id you can find it in the kiosk url.
- Check out my GitHub Readme
https://github.com/NLfrans/FusionSolar/blob/main/README.md - Restart Home Assistant
