*Connect the pi to the inverter WiFi network
*Connect the Pi LAN interface to your regular LAN (same network as your HA server) and give the Pi a static IP.
*Follow the guide above to set up your Pi as a bridge.
*Enter a static route in your home router that routes all traffic to the Inverter to the LAN IP of your Pi.
Once this lands in a release version of pymodbus (and it fixes the issue in HA) I’ll update the sensor to use async and try to get in officially in HA.
I thank you for this tutorial. I followed it, and now I can access all the information on my inverter.
However, I am trying to create more sensors, but you are giving me this error. I don’t have much knowledge of homeassistant. Can someone help me to solve the problem?
Hello
first thank you very much for the contribution, it is fantastic.
I need to know if this information can be extracted (in the image numbers 1, 2, 3). If possible, how should I do it or what are the parameters that I have to read
This is how my panel is right now with the data that I have taken, it is very simple since I am starting the total configuration of my HA. little by little I will improve it I have incorporated more information
I’ve just started using Hass.io 5.10 and I find this error:
2021-01-18 05:36:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for huawei solar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-01-18 05:36:02 ERROR (MainThread) [homeassistant.components.hassio] Platform error sensor.huawei solar - No module named ‘huawei_solar’
Hi Emilv,
first of all, thank you very much for this integration. I was slowly going crazy with the limitations of the Huawei app, and after discovering home assistant two months ago was overjoyed to find there is a solution to read the inverter data!
I was curious though how people coped with the inverter shutdown. At least my installation (Sun2000-15KTL) shuts completely down when there is no power from the solar panels, including the wifi. In the morning home assistant does not seem to recover the connection without a restart(I am running a supervised docker installation on an Intel NUC). I guess I could use an automation to restart 10 minutes after sunrise or so, but I was wondering if there is a more elegant solution.
Hmm seems I was to hasty. For future reference, the 2000 series seems to enter a state when illumination is detected where the dongle starts to connect to the huawei servers, but the internal wifi either does not accept connections yet or will not report proper values. As illumination rises the inverter enters the state ‘grid-connected’, where it will report properly, and everything works from there. It’s only we have some snow right now, so it took a while for the panels to start producing
Say, you don’t have a ‘buy me a beer’-button somewhere? I wouldn’t mind showing my appreciation for your work!
Cheers,
Boris
I have sun2000-8ktl, There is no problem with WiFi dongle or internal WiFi when no illumination. For me it’s always on and connected to huawei server and HA even at night. Maybe there is some setting in HomeFusion App to change behavior of the inverter.
Hi, I am very grateful for your work with the integration.
I have access to a SUN2000-5KTL-L1 (actually grid power limited) and a SUN2000L-5KTL (on-grid) and the behaviour is the same. For the moment, I can’t notice any difference.
Both inverters are directly connected to the carrier wifi router directly.
