well… i have mine as above, and i have all sorted
i can see every consume, energy etc and also the total amount from grid, battery and PV
Okay, then it has something to do with the fact that i have 2 cascading inverters connected in the group sensor.inverter_active_power_group to get the overall power of both inverters. Do you have more than one inverter?
i have on
but i guess you just have to do a plus
something like this i guess (guessing a lot !!)
{% set meter_power1 = states(‘sensor.power_meter_active_power-1’) | float %}
{% set meter_power2 = states(‘sensor.power_meter_active_power-2’) | float %}
{% set inverter_power1 = states(‘sensor.inverter_active_power-1’) | float %}
{% set inverter_power2 = states(‘sensor.inverter_active_power-2’) | float %}
{{ ((inverter_power1 + inverter_power2) - meter_power ) | float(0) }}
I’m experiencing the same problem as described here since lastest HA core and superviser update
Any idea how to investiguate?
All you need is this, also the ‘max(0,’ will stop it showing negative values on the inverter(s) active_power, which they normally show each inverter with a battery discharging at night.
########### Start: Power Meter - Calculates the Active Power being consumed in the house from grid, inveters & battery ###########
# Provides the calculated current load, in Watts, of the house including power being drawn from solar, battery & grid.
- sensor:
- name: "House Consumption - Power"
unique_id: house_consumption_power
unit_of_measurement: "W"
icon: mdi:home-lightning-bolt-outline
device_class: "power"
state_class: measurement
state: >-
{% set inverters_power = states('sensor.inverters_active_power') | float(default=0) %}
{% set power_meter_power = states('sensor.power_meter_active_power') | float(default=0) %}
{{ max(0, (inverters_power - power_meter_power)) }}
availability: >-
{{ states('sensor.inverters_active_power') | is_number
and states('sensor.power_meter_active_power') | is_number }}
@cailloup this thread and the WLCRS issues area have the same people looking at it. Just subscribe to the issue you’ve flagged for updates. You’ll also see that the WCLRS dev has already replied pointing out its a ‘clash’ between two integrations both using python, but expecting/compatible with different versions of it.
Here my Card:
type: vertical-stack
cards:
And thanks a lot for your information about Huawei Values
Is there any possibility to see the grid voltage as entity or attribute? I upgraded the firmware of my 5KTL-M0 inverter to SPC130 today and as far as I remember in SCP117 the grid voltage was shown as entity.
Hi @Ribe
Could you please edit your post above, as you’ve pasted the code as normal text, meaning the formating and some characters has been broken.
When posting yaml on this site, you need to enter 3 of the ` (the key usually to the left of the 1 key, or the key that also has the tilde ~ character on it) before you paste the code, then close the code section by placing another 3 of them at the end of the code.
This gives this code section appearance in which format / character / indents etc are maintained, e.g.:
Yaml needs to be pasted between ``` to start and ``` at the end, to maintain formattng etc.
Just had to upgrade to beta version 1.4.0a1. to solve the issue
Does anyone know where we should report notes about the 1.4.0 alpha? Doesn’t make sense in the forum, does it? So as a GitHub issue?
I’m asking because I noticed that my battery device is listed as a duplicate device in the alpha.
mine stopped working
had to rollback
cards:
- square: false
type: grid
cards:
- type: gauge
entity: sensor.consumed_total_power
max: 12
severity:
green: 0
yellow: 0.001
red: 0
- type: gauge
entity: sensor.solar_plants_total_power
max: 10
severity:
green: 0.001
yellow: 0
red: 0
needle: false
min: 0
columns: 2
- square: false
type: grid
cards:
- type: gauge
entity: sensor.inverter_input_power
max: 11.65
- type: gauge
entity: sensor.ecu_current_power
max: 1200
columns: 2
- square: false
type: grid
cards:
- type: gauge
entity: sensor.battery_energy
needle: true
severity:
green: 1
yellow: 0.001
red: 0
min: 0
max: 10
- type: gauge
entity: sensor.battery_charge_discharge_power
name: Descarga / Carga
max: 5
needle: true
severity:
green: 0.01
yellow: -5000
red: 0
min: -5
columns: 2
- type: horizontal-stack
cards:
- square: false
type: grid
cards:
- type: picture
image: local/homeassistant_images/Tarifas_Electricidad_HA_LV.png
columns: 1
- type: gauge
entity: sensor.power_meter_active_power
min: -9.9
max: 9.9
needle: true
severity:
green: 0.001
yellow: -9.9
red: 0
- square: false
type: grid
cards:
- show_name: true
show_icon: false
type: button
entity: sensor.consumed_energy_daily
show_state: true
icon_height: 20px
icon: mdi:transmission-tower-import
theme: Fluent Orange
- show_name: true
show_icon: false
type: button
entity: sensor.solar_energy_daily
show_state: true
icon_height: 20px
theme: Fluent Blue
- show_name: true
show_icon: false
type: button
entity: sensor.power_meter_consumption_daily
show_state: true
icon: mdi:home
icon_height: 20px
theme: Fluent Red
- show_name: true
show_icon: false
type: button
entity: sensor.power_meter_exported_daily
show_state: true
icon_height: 20px
theme: Fluent Green
columns: 4
Did you get this fixed?
sorry if I missed this, but I haven’t been around for quite some time since the integration was working perfectly. Today, I updated to 1.3.3 and Home Assistant 2024.4.3 and now the power meter active power value is not updated anymore. What could be the problem?
Any hints are highly appreciated!
Thanks and regards!
UPDATE: I installed v1.3.4beta and now it seems to work again. I guess it was the pymodbus problem also reported on Github.
hello
just notice a new “field”
what is “Inverter Power deratin” ?
I’ve recently installed a grid balancing computer from a company in Sweden that takes over my battery Luna2000 and uses it for balancing the power grid, instead of using the battery yourself. The benefit being you get paid to do so.
Now that the balancing computer is installed and is communicating via Modbus TCP with the SDongle, I can no longer establish a connection to HA via @wlcrs integration Huawei Solar.
Is it not possible to establish two different connections via Modbus to the SDongle? Even if one of them is only for monitoring?
@Millet
It’s mentioned in a number of places / threads, that the connections via sDongle / AP can only support a single modbus connection.
The SmartLogger 3000A supports multiple connections, but is NOT supported by the WLCRS integration. It appears that the forthcoming EMMA device ‘MAY’ be able to support multiple connections, however it hasn’t been released widely yet and is still pending if/when WLCRS will add support for it.
Hello, I read with interest your discussion.
In my case the input power is different from the active power, but the battery is fully charge.
My electricity provider did not signed my contract yet, so I’m not allowed to export to the grid. There’s a feature in my huawei inverter for this specific case. There is a limitation in the production not to export.
→ So my assumption is (I put aside the battery) that the import power reflect the real production from the panels, while the active power is a reduced ammount of power calculated to match the house consumption without any excess production that may be exported.
This is just my assumption and I’d be very interested to know your opinion about it.
Actually the reason why I’m interested in understandinv the inverter input power meaning is that I need to know the “real” production of my panels. I guess it would be the inverter active power + exported power. But as I don’t export and my inverter automaticaly limits the production, it’s not so easy to find.
→ any idea would be more than welcome.
Thank you for rhe clarification. I read that it supports only one connection type, but I could not find anything about two of the same type.
I’m assuming the smart logger takes up the same spot as the SDongle or can they be run at the same time?
Is there is any -other- way to get the inverter data into HA?
