Integration Solar inverter huawei 2000L
Thanks for the tip. I was able to add Sonoff Pow2 using Alexxit’s SonoffLan control to Energy dashboard. GitHub - AlexxIT/SonoffLAN: Control Sonoff Devices with eWeLink (original) firmware over LAN and/or Cloud from Home Assistant
Steps are simple
  1. configuration
  2. Scroll down to Customizations
  3. select your entity
  4. select device class as “energy”
  5. select state class as " measurement"
  6. Select other
  7. Attribute name “last_reset”.
    8 attribute value “1970-01-01T00:00:00+00:00”
  8. click save
  9. Now your sensor will show up in energy dashboard.
I don’t know why every day start with -43kwh in chart.
Probably you ara using the daily yield.
At midnight night it goes down the yesterday production.
I use Total yield… And everything it’s ok.
I think the last_reset definition can solve…
But I don’t know how.
If the last reset was set to last midnight…
Anyone can do that?
The only this I have not working is the CO2.
The integration is OK… I have the value on my lovelace… But the Energy dashboard say… Can’t calculate…
Any help?
Thanks everybody
GP
How did you get access to the firmware? I have a ticket open with Huawei at the moment to get access to it, but for some reason none of my accounts seem to allow me to download anything other than V100R001C00SPC110 release, and even then they won’t let me download that, stuck on V100R001C00SPC109
thanks .i changed to Total yield. hope all will be ok now
https://easyupload.io/pyh5l5 got it from them 10 days ago, SPC122.
Is there anything big that have been changed lately ??..
Beacuse my sd card crashed a while ago and have had it working then . but now after i got my backup installed in a ssd i cant get it to connect to the inverter anymoore ??
i get these errors below
Is there anything that i need to change ??
My settings in config is
  - platform: huawei_solar
    host: 192.168.8.1
    optimizers: false
    battery: false
    slave: 0
And i have also tride to use slave 1 but with the same results
Logger: homeassistant.components.sensor
Source: custom_components/huawei_solar/sensor.py:130
Integration: Sensor (documentation, issues)
First occurred: 3:25:26 PM (1 occurrences)
Last logged: 3:25:26 PM
Error while setting up huawei_solar platform for sensor
  File "/usr/local/lib/python3.9/site-packages/huawei_solar/huawei_solar.py", line 293, in read_register
    response = self.client.read_holding_registers(
  File "/usr/local/lib/python3.9/site-packages/pymodbus/client/common.py", line 114, in read_holding_registers
    return self.execute(request)
  File "/usr/local/lib/python3.9/site-packages/pymodbus/client/sync.py", line 108, in execute
    raise ConnectionException("Failed to connect[%s]" % (self.__str__()))
pymodbus.exceptions.ConnectionException: Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.8.1:502)]
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/config/custom_components/huawei_solar/sensor.py", line 115, in setup_platform
    HuaweiSolarSensor(inverter, config[CONF_OPTIMIZERS], config[CONF_BATTERY])
  File "/config/custom_components/huawei_solar/sensor.py", line 130, in __init__
    self._name = self._inverter.get("model_name").value
  File "/usr/local/lib/python3.9/site-packages/huawei_solar/huawei_solar.py", line 265, in get
    response = self.read_register(reg.register, reg.length)
  File "/usr/local/lib/python3.9/site-packages/huawei_solar/huawei_solar.py", line 298, in read_register
    raise ConnectionException(ex)
huawei_solar.huawei_solar.ConnectionException: Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.8.1:502)]
Logger: pymodbus.client.sync
Source: /usr/local/lib/python3.9/site-packages/pymodbus/client/sync.py:218
First occurred: 3:25:18 PM (2 occurrences)
Last logged: 3:25:25 PM
Connection to (192.168.8.1, 502) failed: timed out
Logger: huawei_solar.huawei_solar
Source: /usr/local/lib/python3.9/site-packages/huawei_solar/huawei_solar.py:297
First occurred: 3:25:25 PM (1 occurrences)
failed to connect to device, is the host correct?
Thanks for the link, though for some reason it refuses to upgrade on my unit. I did finally hear back from the Huawei support team, and they also supplied me the SPC118 release and SPC122 and neither works. I hope it’s just a case of my current firmware being so old that there is an intermediate release which I can see SPC110 is released on the main site. Waiting yet again to hear back, in the meantime I am back to querying it over the internal inverter wifi. Not that it doesn’t work, but it’s messy, and would much rather it simply be on the LAN.
No one that can help me out ??
Check if inverter IP is still 192.168.8.1. I know few people that after firmware update it changed to 192.168.200.1. You can also check if the connection to inverter is working correctly and try if modbus integration is working correctly. If you can ping inverter from HA and modbus integration is working, then there is something wrong with huawei_solar integration. Did you update also files from huawei_solar integration?
The inverter still has the ip 192.168.8.1 and my Dongle has the software version :
V100R001C00SPC118.
But i try to connect to the internal wifi of the inverter with the interna wifi from RPI4
Cant upgrade to any newer in the device upgrade ??.
The problem now is that i cant find the wifi from Home assistant to the inverter … i have used the NMCLI to connect to it .
But when i take my phone i can find the network and connect to it .
I dont know how to be able to ping it from HA but it dont connect to it it says
First occurred: 4:33:01 PM (2 occurrences)
Last logged: 4:33:08 PM
Connection to (192.168.5.1, 502) failed: timed out
Here above i tried to change to 192.168.5.1 but still the same
I have made a clean install with everything but still the same outcome sadly …
I have the dongle connected by cable but cant get it to work by that way either …
If I correctly understand, the problem is connection from HA to the inverter.
You can use https://www.home-assistant.io/integrations/ping/ to check if HA see inverter. If you want to use LAN you must have *SPC120 or *SPC122 firmware in smart dongle (it was posted in this topic: Integration Solar inverter huawei 2000L - #594 by andro1, and manual how to upgrade smart dongle: Integration Solar inverter huawei 2000L - #514 by giuseppe07)
This is my first post …Hello everyone
I have a Sun2000-8KTL-M1 inverter. I asked tech support for a new dongle firmware and got this answer:
My recommendation for you is to wait until the improved version SPC123 for the SDongle will be launched by the end of this week as expected.
I also recommend you to upgrade your inverter to the latest SPC135 (currently, your inverter is running SPC133).
Please let me know, do you want me to perform the upgrade for you remotely? or do you prefer to provide you the SPC135 software package?
So it looks like it. that Version SPC122 seems to have some problems.
sorry but I have problem witho solar item of new energy panel.
I try our idea but not work for me
  • platform: template
    sensors:
    solar_daily:
    friendly_name: “Energetica giornaliera”
    unit_of_measurement: ‘kWh’
    icon_template: mdi:solar-power
    value_template: “{{ state_attr(‘sensor.sun2000l_3ktl’, ‘daily_yield’) }}”
I view 0 value
How do you upgrade fromn a downloaded file ?? i dont have acess to that filename in my login only older versions but cant find any upload button
okey but it wont connect so i cant ping it sadly … and the versions you talk about i cant upgrade to they dont show up and i cant upload any file either
Hi Guys, does anyone knows how to integrate Huawei inverter+power meter via RS485? I have RPi+USB -RS485 converter?
You’ll need the SPC122 firmware to access modbus over the dongle locally, but that firmware version won’t show up in the web portal as yet, you have to manually upgrade it using the Fusion Home app in commission/installer mode.
I just went through this with Huawei support, though for me specifically it was due to being on SPC109 which doesn’t support the upgrade path in their documentation, need at least SPC115 or higher to use the app to upgrade it locally. Otherwise you need installer access on the cloud portal to get to at least SPC115/116 then you can go to the SPC122.
In terms of the upgrade, since you are on SPC118 you should be able to upgrade locally following the upgrade guide in the release documents zip below (section 3.4.2). Basically open the fusion solar app, go into device commission mode, select the dongle as the device type you want to upgrade. Then you need to connect to the dongle over the local wifi (that the dongle creates on power up), or over your local network directly. Assuming the installer password has not been changed the password will be 00000a, then go to the maintenance section, and then select the packge.zip file with SPC122 and upload that.
Files are available here.
https://easyupload.io/m/ury5gu
Any possibility of turning on and of the inverter over homeasstant ??
When is inverter connected with HA it is impossible connect over Fusionhome app.
Got my inverter installed today and thought: Install the github in HACS, start it and you’re set. Well. Total fail. This is by far the most complex piece of software to install, and very little documentation compared to the complex situation - please don’t take that as sounding ungrateful - i just thought it would be easier :wink: ). I flew over those 600 posts, and THINK that I got a little more knowledge now.
With my dongle being on version 100 (or is it 1.00?) it’s not possible to connect modbus over tcp on ethernet. I wish I could do it over wifi, but adding wifi to the RPI4 and then having other problems (wifi connection being not stable) was a no-go.
So I dl’d the 1.22 firmware and wanted to flash it. But I haven’t got the installer password. Seems this is “owned” by the company that installed it. Any way to reset it? This hardware belongs to me, so I expect to have full control over it?!
Is it possible to upgrade the dongle w/o installer rights? There is NO device management tab in my fusionwebportal.
And if I can’t reset the installer pwd: What is the wifi-pwd of the inverter’s AP? How would I connect the RPI to it w/o knowing the AP-password?
Thanks everybody!
