It would be helpful if it were possible to query the consumption values of the last day. This makes an accurate consumption analysis possible. The values of the current day cannot be used for this because viessmann does not calculate the values at exactly midnight but rather a little later. This means that the exact consumption is not always completely included in the daily values. The values are contained, for example, under api.getGasConsumptionHeatingDays()[1].
I agree that this is offset by half an hour or so.
But if you use ENERGY dashboard, is it still wrong?
Sorry, I’m new to Home Assistant. It may be possible to change values from the previous day afterwards. I use Node-Red and a Google Sheet for my analysis. It would be enough for me if the entity “LastDay” were available. But perhaps the integration can also take this into account directly.
