Let me share with you a piece of configuration that might be useful for those who own an InelNet Internet central control unit by Inel to control their appliances. The unit controls blinds, roller shutters, awnings, garage doors, drive-in doors, light sources, and mains sockets.
In the examples presented here, the InelNet unit is controlled by HTTP requests. You get a set of predefined REST requests that you can use to control appliances paired with the unit.
Setup
Before you start, it is assumed that you have an InelNet unit already configured and paired with the appliances you want to control by Home Assistant.
What’s important, the unit should have a static IP address assigned (see DHCP settings in your router’s configuration). Otherwise, the proposed configuration will stop working whenever the IP address of the unit changes. Alternatively, a host name is a valid solution as well.
Configuration
The approach described below uses HTTP requests to send control commands to an InelNet unit. The example defines requests to raise, lower or stop a cover associated with a particular channel. The inelnet_program request, on the other hand, lets you switch a cover controller to programming mode when there is a need to pair a remote control with it.
The listed commands will work with cover controllers (for example Inel ST-01R), but are not limited to them (for example, the inelnet_up or inelnet_down commands may trigger an Inel ORS-X1T switch as well).
Examples
Before you use the example, replace the INELNET_UNIT_IP_ADDRESS placeholders with the static IP address or host name of your InelNet unit.
# Example configuration.yaml entry
rest_command:
# raises the cover associated with the specified channel
inelnet_up:
url: 'http://INELNET_UNIT_IP_ADDRESS/msg.htm'
method: post
content_type: 'application/x-www-form-urlencoded'
payload: 'send_ch={{channel}}&send_act=160'
# raises the cover associated with the specified channel (short movement)
inelnet_up_short:
method: post
payload: 'send_ch={{channel}}&send_act=176'
# lowers the cover associated with the specified channel
inelnet_down:
method: post
payload: 'send_ch={{channel}}&send_act=192'
# lowers the cover associated with the specified channel (short movement)
inelnet_down_short:
method: post
payload: 'send_ch={{channel}}&send_act=208'
# stops the cover associated with the specified channel
inelnet_stop:
method: post
payload: 'send_ch={{channel}}&send_act=144'
# switches the cover controller associated with the specified channel
# to programming mode so you can pair a remote control with it
inelnet_program:
method: post
payload: 'send_ch={{channel}}&send_act=224'
Having defined the REST commands above, you can use them to create a cover template like in the example below. Make sure to replace the MY_BLIND_CHANNEL_NUMBER placeholder with a proper channel number that your cover is associated with in your InelNet unit configuration.
cover:
covers:
# adjust the entity ID
living_room_blind:
device_class: blind
# adjust the unique ID and name
unique_id: living_room_blind_id
friendly_name: "Living room blind"
# InelNet does not support positions and the states of covers,
# so let's use 50 to always enable cover movement in either direction
position_template: 50
open_cover:
service: rest_command.inelnet_up
# replace with a proper channel number, e.g. 1
channel: MY_BLIND_CHANNEL_NUMBER
close_cover:
service: rest_command.inelnet_down
stop_cover:
service: rest_command.inelnet_stop
