Requesting integration with Beurer scales, is it possible? I have a Beurer BF 720 scale with Bluetooth, and it would be great to get all the statistics from it in Home Assistant to keep track of my weight loss progress.
It should be possible, I have the same model and I don’t use the official app but the OpenScale Android app instead. As the name suggests, this is open source software (GitHub - oliexdev/openScale: Open-source weight and body metrics tracker, with support for Bluetooth scales). So it’s clearly possible to communicate with it (it uses BLE if I’m not mistaken). Would definitely be interested in an integration.
Between BT Scale and OpenScale the hard work of talking to the devices seems mostly done.
I have a similar model and might have a stab at an integration.
Hi, did you have a chance to look at this?
Tried to find a solution but gave up and bought a Eufy C1 scale instead. Works like a charm
