Integration with Frigate - Problems retrieving Clips
Hi Y’all,
I’m using Frigate and node red to send video clips of events to telegram.
It used to be that I could upload the clips from the Media Folder, however, since the last update of Frigate it’s no longer possible. I’ve tried to incorporate the link structure shown in the Frigate documentation, but Node Red says that the file I link to isn’t there - even though its accessible through the browser at the same URL.
Above is the flow - the comments show the link to the file being used in each instance. The top injection works (but links to the old file location) - while the bottom throws out the error message on the File buffer node “ENOENT”. Any ideas? I’ve searched read through all the comments above and tried all the different URLs but nothing has worked. Thanks!
Working in something similar. Did you solve it?.
Would you mind to share the flow?
[{“id”:“85dcda3beabccda7”,“type”:“tab”,“label”:“Поток 1”,“disabled”:false,“info”:"",“env”:[]},{“id”:“5c4ea15986767c0a”,“type”:“mqtt in”,“z”:“85dcda3beabccda7”,“d”:true,“name”:“Frigate”,“topic”:“frigate/events”,“qos”:“2”,“datatype”:“json”,“broker”:“1585b4ea309e07e0”,“nl”:false,“rap”:false,“inputs”:0,“x”:90,“y”:120,“wires”:[[“2e62afc341b4a8a8”]]},{“id”:“ae90b92bd306a315”,“type”:“change”,“z”:“85dcda3beabccda7”,“name”:“Extract Data”,“rules”:[{“t”:“set”,“p”:“eventid”,“pt”:“msg”,“to”:“payload.after.id”,“tot”:“jsonata”},{“t”:“set”,“p”:“camera”,“pt”:“msg”,“to”:“payload.after.camera”,“tot”:“jsonata”},{“t”:“set”,“p”:“object”,“pt”:“msg”,“to”:“payload.after.label”,“tot”:“jsonata”},{“t”:“set”,“p”:“zone1”,“pt”:“msg”,“to”:“payload.after.entered_zones[0]”,“tot”:“jsonata”},{“t”:“set”,“p”:“filename”,“pt”:“msg”,“to”:""/media/frigate/thumbs/" & msg.zone1 & “/” & msg.object & “/” & msg.mydt & “-” & msg.camera & “-” & msg.eventid & “.jpg”",“tot”:“jsonata”},{“t”:“set”,“p”:“url”,“pt”:“msg”,“to”:"“http://192.168.1.134:5000/api/events/” & msg.eventid & “/thumbnail.jpg”\t",“tot”:“jsonata”}],“action”:"",“property”:"",“from”:"",“to”:"",“reg”:false,“x”:430,“y”:120,“wires”:[[“86abd48abd25fb73”]]},{“id”:“487842f86e3f08dc”,“type”:“file”,“z”:“85dcda3beabccda7”,“name”:“Save Image”,“filename”:“filename”,“filenameType”:“msg”,“appendNewline”:false,“createDir”:true,“overwriteFile”:“true”,“encoding”:“none”,“x”:150,“y”:200,“wires”:[[“d2a5fac594becdfb”,“56eb19a28f22c9d9”]]},{“id”:“2e62afc341b4a8a8”,“type”:“moment”,“z”:“85dcda3beabccda7”,“name”:“Nice Date & Time”,“topic”:"",“input”:“frame_time”,“inputType”:“msg”,“inTz”:“Australia/Perth”,“adjAmount”:“0”,“adjType”:“days”,“adjDir”:“add”,“format”:“YYYY-MM-DD_HHmm”,“locale”:“C”,“output”:“mydt”,“outputType”:“msg”,“outTz”:“Australia/Perth”,“x”:250,“y”:120,“wires”:[[“ae90b92bd306a315”]]},{“id”:“86abd48abd25fb73”,“type”:“http request”,“z”:“85dcda3beabccda7”,“name”:"",“method”:“GET”,“ret”:“bin”,“paytoqs”:“ignore”,“url”:"",“tls”:"",“persist”:false,“proxy”:"",“insecureHTTPParser”:false,“authType”:“basic”,“senderr”:false,“headers”:[],“credentials”:{“user”:"",“password”:""},“x”:590,“y”:120,“wires”:[[“487842f86e3f08dc”]]},{“id”:“d2a5fac594becdfb”,“type”:“image”,“z”:“85dcda3beabccda7”,“name”:"",“width”:160,“data”:“payload”,“dataType”:“msg”,“thumbnail”:false,“active”:true,“pass”:false,“outputs”:0,“x”:340,“y”:280,“wires”:[]},{“id”:“56eb19a28f22c9d9”,“type”:“function”,“z”:“85dcda3beabccda7”,“name”:“function 10”,“func”:“msg.payload = {\n content: msg.payload, //the image buffer caption: There’s someone in the frontyard. `,\n type: ‘photo’,\n chatId: 1112277522\n\n}\nmsg.payload.options = { parse_mode: “Markdown” };\nreturn msg;”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:340,“y”:200,“wires”:[[]]},{“id”:“1585b4ea309e07e0”,“type”:“mqtt-broker”,“name”:"",“broker”:“192.168.1.134”,“port”:“1883”,“clientid”:"",“autoConnect”:true,“usetls”:false,“protocolVersion”:“4”,“keepalive”:“60”,“cleansession”:true,“birthTopic”:"",“birthQos”:“0”,“birthPayload”:"",“birthMsg”:{},“closeTopic”:"",“closeQos”:“0”,“closePayload”:"",“closeMsg”:{},“willTopic”:"",“willQos”:“0”,“willPayload”:"",“willMsg”:{},“userProps”:"",“sessionExpiry”:""}]
When I import the code node red show syntax error, please can you share a new one?. Thanks
