Integration with ID Lock 150
Ok, thanks.
I have tried that and i get more functonality whit LUA-script in my tellstick controller. I’ll wait for update of OZW.
Kind regards
Andreas
Hi, what is possible at the moment with Home Assistants Z-wave and ID Lock 150?
  • Lock/unlock (I guess)
  • See who last locked/unlocked?
  • Combine tag and code?
  • Insert new users/codes?
Thanks,
Anders
yes.
Peter
Hi Peter
Due to poor function with tellstick and LUA i gave up that and included my lock in Home-assistant and got it working nice. But i only get registerd that its unlocked by “Keypad Unlock”, what do i need to change to see which code is used or is this not possible?
Andreas
I have not looked into the notifications in detail, but I’ve read people have gotten this to work. You can read the doc here for the latest version: https://idlock.no/wp-content/uploads/2019/08/IDLock150_ZWave_UserManual_v3.02.pdf
Which fw version do you run on the lock and Z-Wave module? Updating the last one (1.6) might be needed, and is a bit of work. Check here: https://idlock.no/z-wave_updater/
HI. I have the lock now and it works fine, but so far I have used grep to filter out the statuses from the OZW_Log. It works, but it’s a hassle.
I run hass.io, can you please explain how to use the linked https://github.com/sveip/open-zwave/blob/d1112dba2a117635ed0268f294b29d94adb0d031/config/idlock/idlock150.xml ?
And after that, do I get more info as attributed to the sensors, or how can I find the information like last lock/unlock code/tag and so on?
Thanks,
Anders
Hi everyone. I do not know if this is the right place but here goes. After working a lot to get my ID lock 150 working properly - after a new installation of Hassio on synology the secure password was set automatically, meaning reset of the whole z-wave network. Everything has been workign since.
Now after a battery change It seems that the ID-Lock lost the “secure” connection again. Anyone had that issue? Do you need to do something special when you change batteries? reconnect secure again?
Thanks,
Pär
Hej Per
Hur menar du att låset tappat säker anslutning? Har aldrig efter batteribyte behövt göra något.
Testa att exkludera och inkludera igen men du skall normalt inte behöva göra detta pga batteribyte.
Hi Per
How do you mean the lock lost secure connection? Never had to do anything after changing the battery.
Try to exclude and include again but you should not normally do this because of battery change.
Regards Andreas
Hi Andreas,
exactly lost secure connection (as far as I can see) and the node is presumed dead. I was not able to
exclude and include again. I had to remove the integration and start over - but strange if no one else has had the same issue. I’ll let you all know if it happens next time again.
Thanks!
Tjena Andreas!
Har själv ett id lock 150 och fungerar riktigt bra för mig med HA hittils. Men vet ej hur jag ska kunna se vem det är som låser upp dörren! Har du lyckats lösa det och har lust att säga hur? :slight_smile: Mvh
Tjena
Det funkar inte med ordinarie z-wave integrationen i HA som baseras på open z-wave 1.4. Jag har klivit över till mqtt z-wave där jag nu får upp direkt i HA vem som låste upp. Så jag rekommenderar varmt att byta då det dels underlättar omstarterna men även att jag upplever lite snabbare respons.
Mvh Andreas
Tack för svar adde! ska kika på det nu.
Skickade även ett PM till dig med en fråga :slight_smile:
Hi!
Are you guys able to see if the lock is in away mode? I’m using the new ozw beta and I can’t see any attributes/entity with that information
Hi, its not possible to se that. But you can make a template switch that change away mode and in that way know.
/Andreas
Okay, does that work if I lock with pincode and activate the away mode? Or do I need to activate the away mode with a template switch that set the lock in away mode?
Only way right now is to use template button to activate away mode. There is no way im aware of to read settings in ozwd from HA. So its a work around.
Ok! I understand, thank you :+1:
Hi, how can you see which code is used to unlock the door? I can’t find that anywhere.
Ok got some parts to work with ozw beta but the zwave integration seems to be in a really early beta stage I must say.
