Broken for me also since 0.92.0 as @Par_Hedberg says, deleting and re-adding fixes the issue. Restarting hass breaks it again though
hi, there is a way to see āLogā or event?
and about an active alarm, have only a warning only on phoneapp? not on HA?
The events are shown as binary sensors, ha can log that for you.
Tha alarm should show up as both as an event for you to use as an automation and in the alarm panel.
Is this not working for you?
on lovelace i have all
- binary_sensor.home_battery - binary_sensor.home_button_press - binary_sensor.home_cold - binary_sensor.home_connectivity - binary_sensor.home_dry - binary_sensor.home_heat - binary_sensor.home_moisture - binary_sensor.home_sound - binary_sensor.home_tamper
- sensor.home_humidity - sensor.home_pressure - sensor.home_sound_level - sensor.home_temperature
and
arm_away
on alarm panel on lovelace
if āturn alarm onā from app, moved under, let it detect and wait 45 second, point start to play alarm sound. good.
on phoneapp have āMotion detected!ā and notification. good.
on lovelace alarm panel icon only turn from green āactivateā to red āawayā. nothing more. canāt see āmotion detected triggedā and/or is playng sound alarm.
(binary_sensor.home_button_press change if press point. good)
Alarms should show up in the alarm panel but Iāve never been able to test it. Will report back once I get some more time.
Had some time to test the triggers and this Webhook is received by my home-assistant, it should be populated by the alarm component but there seems to be an issue with that.
2019-07-21 09:42:38 DEBUG (MainThread) [homeassistant.components.point] Webhook a3375c6f3b7f9baf239...1c37c0aa2f94f7865386d4:
{'hook_id': '5c669e...5ce5a0',
'secret': '8988461...fbfc032df3d6a5',
'event': {
'id': '5d34176...001a15238',
'type': 'alarm_grace_period_expired',
'user_id': '5b29f03...018688eb',
'created_at': '2019-07-21T07:42:38.337Z',
'device_id': '5b29f0...b37aa47'
'hook_digest': 'a06d195c65...4fbcb227554cafb46ff9'}
Iāll try to investigate that some more but the debugging setup is quite complex so canāt give an estimate on when it is done. In the meantime build an automation like this to handle alarms:
- id: point_alarm
alias: Point alarm
- event_type: point_webhook_received
platform: event
condition:
condition: template
value_template: '{{ trigger.event.data.event.type == ''alarm_grace_period_expired'' }}'
- data_template:
message: 'Point event: {{ trigger.event.data.event.type }}, event data: {{ trigger.event.data}}'
title: Point, {{ trigger.event.data.event.type }}
service: notify.notify
- data_template:
message: '{{ trigger.event.data.event }}'
title: Point alarm
service: persistent_notification.create
Iāve got a PR that fixes the triggered alarm issue: https://github.com/home-assistant/home-assistant/pull/26062
Would be good if someone else also could test and verify that the alarm behaves as expected with this fix.
ok now panel show up new alarm icon when ring.
tnx
A quick question for @fredrike - is it possible to specify config so that only a few devices from the userās point account are retrieved by home assistant? I have a few points scattered around places on my account and Iād only like to retrieve specific ones for a particular home assistant instance.
Is that possible? Iāve had a quick search and canāt see anything but some of that may be that Iām a HA newbie. Pointers, redirects all gratefully received.
Thank you for the integration, btw. Works beautifully (if retrieving slightly more than I need right now! )
Cheers!
Scottā¦
Hi @smackie and welcome to the community!
It is not possible to limit the devices from the Point Integration perspective. But I saw that the Entity Management in 0.98 supports disable entities:
The first feature is that itās now possible to disable entities. If an entity is disabled, it will not be added to Home Assistant when an integration adds it. So now it will be easy to manage which entities will show up. This option is accessible from the entity registry
Iāve not tested it myself but sounds easy to get going.
Iām glad that you find the integration useful!
Fredrik,
Thanks for the reply! Understand about the API. The entity disable function appears to work for me so Iāll use that.
Cheers!
Scottā¦
Could this potentially be used as geofencing? I see the native point minut use this but is there no way to get that into home assistant?
Well you could build automations to when the stage of your point alarm changesā¦
But there are tons of better alternatives for presence supported by hass. https://www.home-assistant.io/components/#-detection
I had a look at the code and it seems doable to add a list of āhome usersā as an attribute to the alarm_panel
created for each Home. Is this feature something that is still needed or did you go for another presence sensor?
It would mean less apps to use gps tracking so it would be nice if not to complicated. Also had a thought if not the motion sensor could be used in HA?
Again, I think other means would be better. Perhaps just looking at the devices connected to your router would be sufficient. Iāll give it a try and see if it can be added.
Of course it can, just build automations from the binary sensor or an automation of the webhook (it is described in the point documentation).
Hi all,
Iām having issues authentication to my Minuts. I run a dockerized installation of HASS and itās working fine with some other integrations. With Minut I get the authorization dialog, I follow the link and successfully authenticate at Minut, thereās a redirect happening to the correct localhost link and it gets both a 200 OK response as well as the OK! file download.
Yet, even though all that happens, when I click submit in the integration auth dialog it tells me I need to first go and authenticate at Minut and try again.
Iām not really sure what could be going wrong here. Let me know what logs etc I can look at. The only thing under Developer Tools that look related are the below, but that seems to just confirm auth problems I think.
Error doing job: Task exception was never retrieved
November 9, 2019, 2:39 PM components/point/config_flow.py (ERROR) - message first occurred at November 9, 2019, 2:25 PM and shows up 5 times
Failed request: 404 Client Error: Not Found for url: https://api.minut.com/v1/users
November 9, 2019, 2:39 PM components/point/config_flow.py (WARNING) - message first occurred at November 9, 2019, 2:25 PM and shows up 5 times
regards,
Troed
That error looks like there have been changes in the api from Minut, I will have a look at it
A developer from Minut reached out to me with a patch for the underlying library used by the homeassistant integration. Iāve merged that and a fix is merged into the homeassistant code. It will hopefully reach the 0.102 release.
