Integration with Plejd dimmers
I installed a Plejd DIM-02 this weekend and got it to work with the android app.
Now Im trying to use @icanos integration to get it to work with HA aswell. The installation seemd to work smothly but when I try to start I get ‘error: unable to retrieve session token response: Error: Request failed with status code 403’.
Peeking at the source I can see calls https://cloud.plejd.com and just to be sure - there isnt a need to have the GW to be able to use this integration, right?
With the asumption that I dont need the GW: I used the email and pwd I use to login to the app as username and password in the integration-config. Is the correct? As site I used ‘Hemma’ which is what i named the setup in the app.
Can anyone help me nail down whats missing?
BR
To me it seems like you have entered your plejd credential wrong, Try to avoid using åäö or any other obscure charactar. Use plain text only.
Here is my config
Addon config:
site: name of your plejd
username: [email protected]
password: password
mqttBroker: 'mqtt://192.168.1.23'
mqttUsername: username
mqttPassword: password
includeRoomsAsLights: false
connectionTimeout: 2
writeQueueWaitTime: 400
MQTT config (not sure if you need it if you have configured MQTT from integration)
mqtt:
  broker: "mqtt://localhost"
  username: !secret mqtt_username
  password: !secret mqtt_password
  discovery: true
  discovery_prefix: homeassistant
  birth_message:
    topic: "hass/status"
    payload: "online"
  will_message:
    payload: "offline"
Hi, i successfully got plejd into ha and found them but i still got a problem. I cant turn on the lights or switch them off for that matter. Any ideas to why this problem occurs.
Thanks for your reply!
I got it to work eventually - I believe it was a trailing space that messed things up.
However, as soon as I got the integration to work it made the plejd-device crash rendering it useless. First I thought it was a faulty device and got anotherone - hooked it up, made sure it was working manually (light-switch) and with the app. But as soon as I got it integrated into HA it stoped working - not only in HA but manually and using the app aswell!
After some calls to Plejd-support (kudos to them) we managed to reset the device(s) and they started to work again using the app and switch so they are not broken. Plejd-support didnt think the problem could be connected to my installation since everything was working correctly without HA.
With this I sort of lost the spirit and havent continued the efforts to get them integrated in HA yet.
BR
Have you got this working?? Im having the same problems…
Get a list of plejd units in HA but can’t turn them on of off ether
Hi Rowlyswe!
I just got my DIM-01 home today to play with. Got the plugin up and running yesterday, and the dimmer was pict up almost perfectly - some error messages at first but now perfect connection every restart.
Have you added the right light setting? I use these settings:
- platform: mqtt
  schema: template
  state_topic: "homeassistant/light/plejd/11/state"
  command_topic: "homeassistant/light/plejd/11/set"
  command_on_template: '{"state": "ON"{% if brightness is defined %}, "brightness": {{(brightness | float * 0.3882 + 1) | round(0)}}{% endif %}}'
  command_off_template: '{"state": "OFF"}'
  brightness_template: '{{ (value_json.brightness | float * 2.55) | round(0) }}'
This works for me at least - will play a few days to see that it is stable.
Kind regards,
/Christer
Hi
I have my lights at: homeassistant/light/plejd
My switches at: homeassistant/switch/plejd
Do you know the Plejd scenes path?
Need some help here. I have an installation with Home Assistant Supervised on Debian on an Intel NUC. Is it possible to integrate Plejd with this setup, and if so, which route should I go?
The bluetooth stopped working on my synology so i bought a GWY-01 instead. Is anyone aware of a addon/plugin that uses the GWY instead of bluetooth?
What is currently the best and most responsive Plejd integration? Does any of them do realtime updates, or is it just pushing / polling seconds later so that its no point trying to use it for controlling lights as a remote?
Seems like the same issue on Android. The site.json is now just “”_inputAddresses":{"$type":“System.Collections.Generic.Dictionary2[[System.String, mscorlib],[System.Collections.Generic.IDictionary2[[System.Int32, mscorlib],[System.Int32, mscorlib]], mscorlib]], mscorlib”
i just got the plejd to work now. Dont know but can i see the how mutch power its using like on shelly?
Plejd doesn’t report energy consumption unfortunately, read somewhere that they do have hw support but not yet supported by sw…
Used icanos addon for over a year without any issues. Yesterday I did a full system reboot (pi 4) for the first time in ages and now plejd devices can’t be controlled anymore as the addon can’t connect to the BT device :
2023-04-08 16:58:38 ERR [plejd-ble] Uh oh, no Plejd device!
2023-04-08 16:58:38 ERR [plejd-ble] Failed to start discovery. Operation already in progress
DBusError: Operation already in progress
    at _methodReturnHandlers.<computed> (/plejd/node_modules/dbus-next/lib/bus.js:343:27)
    at handleMessage (/plejd/node_modules/dbus-next/lib/bus.js:101:11)
    at EventEmitter.<anonymous> (/plejd/node_modules/dbus-next/lib/bus.js:151:9)
    at EventEmitter.emit (events.js:314:20)
    at /plejd/node_modules/dbus-next/lib/connection.js:116:14
    at Socket.<anonymous> (/plejd/node_modules/dbus-next/lib/message.js:63:9)
    at Socket.emit (events.js:314:20)
    at emitReadable_ (_stream_readable.js:557:12)
    at processTicksAndRejections (internal/process/task_queues.js:83:21)
2023-04-08 16:58:38 INF [plejd-ble] If you continue to get "operation already in progress" error, you can try power cycling the bluetooth adapter. Get root console access, run "bluetoothctl" => "power off" => "power on" => "exit" => restart addon.
2023-04-08 16:58:38 WRN [plejd-ble] Failed reconnecting. Failed to start discovery. Make sure no other add-on is currently scanning.
Error: Failed to start discovery. Make sure no other add-on is currently scanning.
    at PlejBLEHandler._startGetPlejdDevice (/plejd/PlejdBLEHandler.js:436:13)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
2023-04-08 16:58:38 INF [device-comm] Bluetooth reconnecting...
2023-04-08 16:58:40 ERR [plejd-ble] Discovery timeout elapsed, no devices found. Starting reconnect loop...
2023-04-08 16:
Replying myself, did as stated in the log… Turned off and on the on board Pi4 bt device and after a while if manged to connect… Strange, never happened before.
Im having the same issues with error messages.
I recently changed from PI4 to a laptop with virtual box and bluetooth usb-adapter.
After i restored my backup I had some issues but I got everything up and running. Now after I rebooted the laptop 2 weeks in the plejd integration stopped working and I cant get it running again. I have changed nothing in the system, but just restarted the host.
Anyone has any idea of what the issue could be?
Any help is much appreciated :slight_smile:
[07:56:34] INFO: Running add-on
Config: {
site: ‘Ruriksvag2’,
username: ‘—scrubbed—’,
password: ‘—scrubbed—’,
mqttBroker: ‘mqtt://192.168.68.93’,
mqttUsername: ‘plejd’,
mqttPassword: ‘—scrubbed—’,
includeRoomsAsLights: false,
preferCachedApiResponse: false,
updatePlejdClock: false,
logLevel: ‘info’,
connectionTimeout: 2,
2023-06-14 07:56:36 INF [plejd-main] Log level set to info
Starting Plejd addon and reading configuration…
2023-06-14 07:56:36 INF [plejd-main] Plejd add-on, version 0.9.1
2023-06-14 07:56:36 INF [device-comm] Starting Plejd communication handler.
2023-06-14 07:56:36 INF [plejd-ble] Starting Plejd BLE Handler, resetting all device states.
2023-06-14 07:56:36 INF [plejd-main] Main Plejd addon init()…
2023-06-14 07:56:36 INF [plejd-api] init()
2023-06-14 07:56:36 INF [plejd-api] Getting cached api response from disk
2023-06-14 07:56:36 INF [plejd-api] login()
2023-06-14 07:56:36 INF [plejd-api] logging into Ruriksvag2
2023-06-14 07:56:37 INF [plejd-api] got session token response
2023-06-14 07:56:37 INF [plejd-api] Get all Plejd sites for account…
2023-06-14 07:56:37 INF [plejd-api] Got site list response with 1: Ruriksvag2
2023-06-14 07:56:37 INF [plejd-api] Site found matching configuration name Ruriksvag2
2023-06-14 07:56:37 INF [plejd-api] Get site details for 6901f2ed-9466-4f42-b752-acbe605f7993…
2023-06-14 07:56:38 INF [plejd-api] got site details response
2023-06-14 07:56:38 INF [plejd-api] Site details for site id 6901f2ed-9466-4f42-b752-acbe605f7993 found
2023-06-14 07:56:38 INF [plejd-api] Saving cached copy
2023-06-14 07:56:38 INF [plejd-api] Getting devices from site details response…
2023-06-14 07:56:38 INF [plejd-api] No Plejd gateway found on site
2023-06-14 07:56:38 INF [plejd-mqtt] Initializing MQTT connection for Plejd addon
2023-06-14 07:56:39 INF [plejd-ble] init()
2023-06-14 07:56:39 INF [plejd-mqtt] Connected to MQTT.
2023-06-14 07:56:39 INF [plejd-mqtt] Sending discovery for 18 Plejd output devices
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot (11 : DAA703BDE80C_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot (13 : C9CFD653ACDB_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered LED-10 (light) named Duschhylla (15 : F8E485A54581_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot vid glasparti (17 : E0E9082A9E11_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered CTR-01 (light) named Bel uteplats (19 : C0D6E03139E9_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered CTR-01 (light) named Entre (20 : CB3FBFA00AF2_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot entre (21 : C2EEAFC89855_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot (23 : F3EDCB061B90_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot korridor (24 : D3124D8D76FB_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takspot (26 : D34B169B7CA9_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered LED-10 (light) named Duschhylla (27 : D87A87534AE6_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Vardagsrum (34 : EF6E7FF09047_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Köksbord (35 : FC13DF04CE08_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takbelysning (37 : C9A32FC368F0_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takbelysning (39 : F8150ED58A66_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered CTR-01 (light) named Garagebelsyning (42 : F5E6267A8969_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Takbelsyning (44 : D1CACA4AC19B_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered DIM-01 (light) named Vårt sovrum (46 : FA18B519BC10_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Sending discovery for 4 Plejd input devices
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered WPH-01 (device_automation) named Garage (41 : FC6B6BE790A8_I_0).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered WPH-01 (device_automation) named Garage (41 : FC6B6BE790A8_I_1).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered WPH-01 (device_automation) named Garage (41 : FC6B6BE790A8_I_2).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered WPH-01 (device_automation) named Garage (41 : FC6B6BE790A8_I_3).
2023-06-14 07:56:39 INF [plejd-mqtt] Sending discovery for 3 Plejd scene devices
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered Scene (scene) named Släck allt (2 : b12f850f-0774-4913-a451-ef07d53f52fa).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered Scene (scene) named Öppna+stäng garageport (4 : dddd77c2-2383-4413-bf71-1492a7284d4b).
2023-06-14 07:56:39 INF [plejd-mqtt] Discovered Scene (scene) named Tänd vardagsrum (5 : c16408be-32ce-4555-9820-4b462bcf8f6e).
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot (DAA703BDE80C_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot (C9CFD653ACDB_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Duschhylla (F8E485A54581_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot vid glasparti (E0E9082A9E11_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn off command for Bel uteplats (C0D6E03139E9_0)
2023-06-14 07:56:40 INF [device-comm] Plejd got turn off command for Entre (CB3FBFA00AF2_0)
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot entre (C2EEAFC89855_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot (F3EDCB061B90_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot korridor (D3124D8D76FB_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takspot (D34B169B7CA9_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Duschhylla (D87A87534AE6_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Vardagsrum (EF6E7FF09047_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Köksbord (FC13DF04CE08_0), brightness undefined
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/6ef1adbc-857c-46a4-9b77-25904c655fc4/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/3e87b137-e88e-45ca-a5ea-1e7253731327/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/016288e7-02f2-4255-abf1-da0d5d206c6a/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/05cfbedb-2b2b-4da9-b463-cdbfe812a245/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takbelysning (C9A32FC368F0_0), brightness undefined
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takbelysning (F8150ED58A66_0), brightness undefined
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/eebaaccc-e9b6-4d4c-bd32-304848c60465/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/29df8f24-3621-4d8b-9269-a0731bff99c2/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 INF [device-comm] Plejd got turn off command for Garagebelsyning (F5E6267A8969_0)
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/cdb75742-7930-4b06-abed-57ed9fb59f09/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Takbelsyning (D1CACA4AC19B_0), brightness undefined
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/95d01a93-b636-4926-be6a-a9833e449995/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:40 INF [device-comm] Plejd got turn on command for Vårt sovrum (FA18B519BC10_0), brightness undefined
2023-06-14 07:56:40 WRN [plejd-mqtt] Device for topic homeassistant/light/plejd/4a0795b1-c219-4aa0-9e6f-d5cc6cee9c69/set not found! Can happen if HA calls previously existing devices.
2023-06-14 07:56:44 INF [plejd-ble] BLE init done, waiting for devices.
2023-06-14 07:56:44 INF [plejd-main] Main init done
2023-06-14 07:56:44 INF [plejd-main] main() finished
2023-06-14 07:56:46 ERR [plejd-ble] Discovery timeout elapsed, no devices found. Starting reconnect loop…
2023-06-14 07:56:46 INF [plejd-ble] Starting reconnect loop…
2023-06-14 07:56:46 INF [device-comm] Bluetooth reconnecting…
at methodReturnHandlers. (/plejd/node_modules/dbus-next/lib/bus.js:343:27)
at EventEmitter. (/plejd/node_modules/dbus-next/lib/bus.js:151:9)
at Socket. (/plejd/node_modules/dbus-next/lib/message.js:63:9)
at emitReadable
2023-06-14 07:50:16 INF [plejd-ble] If you continue to get “operation already in progress” error, you can try power cycling the bluetooth adapter. Get root console access, run “bluetoothctl” => “power off” => “power on” => “exit” => restart addon.
2023-06-14 07:50:16 WRN [plejd-ble] Failed reconnecting. Failed to start discovery. Make sure no other add-on is currently scanning.
2023-06-14 07:50:16 INF [device-comm] Bluetooth reconnecting…
2023-06-14 07:50:18 ERR [plejd-ble] Discovery timeout elapsed, no devices found. Starting reconnect loop…
2023-06-14 07:50:18 INF [plejd-ble] Starting reconnect loop…
2023-06-14 07:50:21 INF [plejd-ble] Reconnecting BLE…
2023-06-14 07:50:21 INF [plejd-ble] init()
2023-06-14 07:50:27 ERR [plejd-ble] Failed to start discovery. Operation already in progress
Did you sort it out?
Any way of restarting the BT service as I did? I assume it would also work in VirtualBox if you run USB passthrough or similar (don’t remember how it’s handled in Virtualbox).
ie “Get root console access, run “bluetoothctl” => “power off” => “power on” => “exit” => restart addon.”
Only happened once for me and it fixed it.
Hi. I have a similar issue. I have two dimmers i want to control. I set up everything according to the instructions. My dimmers show up with the correct name as devices under MQTT. But they both show as “unknown”. I dont see any obvious error in the log. Any tips?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: Plejd
 Adds support for the Swedish home automation devices from Plejd.
 Add-on version: 0.11.0
 You are running the latest version of this add-on.
parse error: Expected string key before ':' at line 1, column 4
[15:57:33] ERROR: Unknown HTTP error occured
 System:   (amd64 / generic-x86-64)
 Home Assistant Core: 2023.11.1
 Home Assistant Supervisor: 2023.10.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:57:33] INFO: Starting the Plejd service...
[15:57:33] INFO: Verified permissions on startup script
[15:57:33] INFO: Executing startup script
[15:57:33] INFO: Running add-on
Config: {
  site: 'Kalhammar Plejd',
  username: '---scrubbed---',
  password: '---scrubbed---',
  mqttBroker: 'mqtt://',
  mqttUsername: 'mqtt-api-user',
  mqttPassword: '---scrubbed---',
  logLevel: 'debug',
  writeQueueWaitTime: 800
2023-11-07 15:57:33 DBG [plejd-main] Log level set to debug
Starting Plejd addon and reading configuration...
2023-11-07 15:57:33 INF [plejd-main] Plejd add-on, version 0.11.0
2023-11-07 15:57:33 INF [device-comm] Starting Plejd communication handler.
2023-11-07 15:57:33 INF [plejd-ble] Starting Plejd BLE Handler, resetting all device states.
2023-11-07 15:57:33 INF [plejd-main] Main Plejd addon init()...
2023-11-07 15:57:33 INF [plejd-api] init()
2023-11-07 15:57:33 INF [plejd-api] Getting cached api response from disk
2023-11-07 15:57:33 DBG [plejd-api] Prefer cache? false
2023-11-07 15:57:33 DBG [plejd-api] Cache exists? Yes, created 2023-11-07T14:56:03.339Z
2023-11-07 15:57:33 INF [plejd-api] login()
2023-11-07 15:57:33 INF [plejd-api] logging into Kalhammar Plejd
2023-11-07 15:57:33 DBG [plejd-api] sending POST to https://cloud.plejd.com/parse/login
2023-11-07 15:57:33 INF [plejd-api] got session token response
2023-11-07 15:57:33 INF [plejd-api] Get all Plejd sites for account...
2023-11-07 15:57:33 DBG [plejd-api] sending POST to https://cloud.plejd.com/parse/functions/getSiteList
2023-11-07 15:57:34 INF [plejd-api] Got site list response with 1: Kalhammar Plejd
2023-11-07 15:57:34 INF [plejd-api] Site found matching configuration name Kalhammar Plejd
2023-11-07 15:57:34 INF [plejd-api] Get site details for 0b19acb7-88fd-432d-bee9-3d0fc7807085...
2023-11-07 15:57:34 DBG [plejd-api] sending POST to https://cloud.plejd.com/parse/functions/getSiteById
2023-11-07 15:57:34 INF [plejd-api] got site details response
2023-11-07 15:57:34 INF [plejd-api] Site details for site id 0b19acb7-88fd-432d-bee9-3d0fc7807085 found
2023-11-07 15:57:34 INF [plejd-api] Saving cached copy
2023-11-07 15:57:34 INF [plejd-api] Getting devices from site details response...
2023-11-07 15:57:34 INF [plejd-api] No Plejd gateway found on site
2023-11-07 15:57:34 INF [plejd-mqtt] Initializing MQTT connection for Plejd addon
2023-11-07 15:57:34 INF [plejd-ble] init()
2023-11-07 15:57:34 DBG [plejd-ble] Found BLE interface 'org.bluez.Adapter1' at /org/bluez/hci1
2023-11-07 15:57:34 INF [plejd-mqtt] Connected to MQTT.
2023-11-07 15:57:34 INF [plejd-mqtt] Sending discovery for 2 Plejd output devices
2023-11-07 15:57:34 DBG [plejd-mqtt] Sending discovery for Lamp staircase
2023-11-07 15:57:34 INF [plejd-mqtt] Discovered DIM-02 (light) named Lamp staircase (11 : F08BB11D6047_0).
2023-11-07 15:57:34 DBG [plejd-mqtt] Sending discovery for Downlights
2023-11-07 15:57:34 INF [plejd-mqtt] Discovered DIM-02 (light) named Downlights (12 : F08BB11D6047_1).
2023-11-07 15:57:34 INF [plejd-mqtt] Sending discovery for 1 Plejd input devices
2023-11-07 15:57:34 DBG [plejd-mqtt] Sending discovery for Hallway
2023-11-07 15:57:34 INF [plejd-mqtt] Discovered WRT-01 (device_automation) named Hallway (13 : DFD7BCBA4B11_I_0).
2023-11-07 15:57:34 INF [plejd-mqtt] Sending discovery for 0 Plejd scene devices
2023-11-07 15:57:34 INF [device-comm] Plejd got turn on command for Lamp staircase (F08BB11D6047_0), brightness 184
2023-11-07 15:57:34 DBG [device-comm] Queueing F08BB11D6047_0 set brightness to 184
2023-11-07 15:57:34 INF [device-comm] Plejd got turn on command for Downlights (F08BB11D6047_1), brightness 201
2023-11-07 15:57:34 DBG [device-comm] Queueing F08BB11D6047_1 set brightness to 201
2023-11-07 15:57:39 INF [plejd-ble] BLE init done, waiting for devices.
2023-11-07 15:57:39 INF [plejd-main] Main init done
2023-11-07 15:57:39 INF [plejd-main] main() finished
2023-11-07 15:57:39 DBG [plejd-ble] Found Plejd service on /org/bluez/hci1/dev_F0_8B_B1_1D_60_47
2023-11-07 15:57:39 DBG [plejd-ble] initDiscoveredPlejdDevice(). Got /org/bluez/hci1/dev_F0_8B_B1_1D_60_47 device
2023-11-07 15:57:39 DBG [plejd-ble] Inspecting /org/bluez/hci1/dev_F0_8B_B1_1D_60_47
2023-11-07 15:57:39 DBG [plejd-ble] Discovered /org/bluez/hci1/dev_F0_8B_B1_1D_60_47 with rssi -83 dBm, name undefined
2023-11-07 15:57:41 INF [plejd-ble] Device discovery done, found 1 Plejd devices
2023-11-07 15:57:41 INF [plejd-ble] Connecting to /org/bluez/hci1/dev_F0_8B_B1_1D_60_47
Stupid question here. But I have just installed Home Assistatn, and when I click on the “+ add integration” from the dashboard, I dont get any hits when I search for Plejd. Do i need to download something on like an USB and then install it directly through my Raspberry Pi 4?
Also, the plejd dimmers are a bit far away from my RPI 4. Do I need like BT extenders to get a good connection? What is recommended if so? (I know that for Zigbee they often use lightbulbs to do the heavy lifting of repeating the signal).
Thanks in advance.
