Has anyone managed to get one of these RC522 RFID readers working?
I can see information for it on esphome.io but cannot see a pinout for wiring and cannot get it communicating.
It’s SPI - the pins are clearly labelled. Follow the i2c SPI example on the ESPHome site.
But my board is slightly different to the one pictured.
You might want to share want the differences are…
Maybe you received a SPI version? How knows?
Yeah - well the original picture is actual SPI (my bad- was on my phone browsing) so you maybe have I2C anyhow. Post a photo of it showing pin labels.
Also note some manufacturers are renaming MOSI and MISO to SDO and SDI, and SS to CS so that causes some confusion.
I’m not sure familiar with SPI, but in most of the wiring diagrams I can fine, which are also Arduino btw, they are wiring all the pins,
as I understand it, SDA normally only needs 2.
This is why im confused. Also, I see a SDA, but no SCL. Goes straight to SCK.
Pick suitable pins for the GPIO - these will work on an ESP32.
spi:
clk_pin: GPIO14 # SCK on this board
mosi_pin: GPIO13 # MOSI (misspelt MOIS)
miso_pin: GPIO12 # MISO
rc522_spi:
cs_pin: GPIO15 # SDA on this board I reckon (no idea why -- I suspect they just change a jumper for I2C board)
reset_pin: GPIO16 # RST
Don’t define a binary sensor - scanning a tag should print it’s data in the log.
Plus of course power and GND.
Im using ESP8266, D1 Mini
Same pins will work on D1 Mini except GPIO16 (D0), use GPIO5 (D1).
Ok, heres what i’ve got.
ESP | RC522
D8 (GPIO15) | SDA
D7 (GPIO13) | MOSI
D6 (GPIO12) | MISO
D5 (GPIO14) | SCK
Oh damn, connected the RST pin and now its working
[23:18:32][W][rc522:398]: Communication with the MFRC522 might be down, reset in -1
[23:18:32][I][rc522_spi:013]: SPI Setup
[23:18:32][D][spi_device:355]: mode 0, data_rate 4000kHz
[23:18:32][E][spi:021]: SPI device already registered
[23:18:32][I][rc522:295]: Soft reset...
[23:18:32][I][rc522:303]: Device online.
[23:18:38][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:18:42][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:18:44][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:18:46][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:18:49][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:18:53][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:18:56][D][rc522:263]: Found new tag '2F-A6-DE-02'
[23:19:37][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:19:41][D][rc522:263]: Found new tag '60-63-EA-1E'
[23:19:43][D][rc522:263]: Found new tag '60-63-EA-1E'
Thank you so much,
You are always very helpful!
Thanks for the info, got mine working following your post. Quick question, how do you list multiple tags?
Binary_sensor:
- platform: rc522
# uid: 5A-64-90-1A,
uid: F7-6C-0D-B3 # Add tag?
name: "RC522 RFID Tag"
How do you get it working?
My wiring is:
esp | rc522 |
D8 (GPIO15) | SDA |
D7 (GPIO13) | MOSI |
D6 (GPIO12) | MISO |
D5 (GPIO14) | SCK |
D0 (GPIO16) | RST |
GND | GND |
3V3 | 3.3v |
My Config:
substitutions:
friendly_name: RFID Reader 01
packages:
esphome.bluetooth-proxy: github://esphome/firmware/bluetooth-proxy/esp32-generic.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: xxxxxxxxxxxxxxxx
wifi:
ssid: !secret wifi_ssid
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
rc522_spi:
cs_pin: GPIO15
reset_pin: GPIO16
My log:
[00:09:28][I][rc522_spi:013]: SPI Setup
[00:09:28][D][spi_device:379]: mode 0, data_rate 4000kHz
[00:09:28][E][spi:021]: SPI device already registered
[00:09:29][W][rc522:399]: Communication with the MFRC522 might be down, reset in 10
[00:09:30][W][rc522:399]: Communication with the MFRC522 might be down, reset in 9
[00:09:31][W][rc522:399]: Communication with the MFRC522 might be down, reset in 8
[00:09:32][W][rc522:399]: Communication with the MFRC522 might be down, reset in 7
[00:09:33][W][rc522:399]: Communication with the MFRC522 might be down, reset in 6
[00:09:34][W][rc522:399]: Communication with the MFRC522 might be down, reset in 5
[00:09:35][W][rc522:399]: Communication with the MFRC522 might be down, reset in 4
[00:09:36][W][rc522:399]: Communication with the MFRC522 might be down, reset in 3
[00:09:37][W][rc522:399]: Communication with the MFRC522 might be down, reset in 2
[00:09:38][W][rc522:399]: Communication with the MFRC522 might be down, reset in 1
[00:09:39][W][rc522:399]: Communication with the MFRC522 might be down, reset in 0
I dont think I got this working. I gave up on this.
It just went in the pile of shitty sensors with poor support. I will try something of a little more quality next time.
I solved my problem. There was an issue in my wiring, because my dev board is slightly different
New wiring:
RFID-RC522 | ESP32-DevKitC-32 |
SDA (SS) | GPIO5 |
SCK | GPIO18 |
MOSI | GPIO23 |
MISO | GPIO19 |
GND | GND |
RST | GPIO21 |
3.3V | 3.3V |
Config changes:
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
rc522_spi:
cs_pin: GPIO5
reset_pin: GPIO21
Thanks to everyone here I was able to get this reader working with an ESP8266 D1 Mini using the GPIOs outlined above. For some reason I couldn’t get it working at first but I changed my config to the pin #s (D8, D7, D6, etc) instead of GPIO# and that got it working. I would recommend that if you’re using home assistant to add
`on_tag:
then:
- homeassistant.tag_scanned: !lambda 'return x;'`
under rc522_spi: so that you don’t have to watch the logs and scanned cards, tags and phones will just show up under Settings\Tags (where you can rename them).
