Integration with Smartalarm
Has anyone tried to connect HA with SmartAlarm (as far as i know a dutch alarm system)
The unit does support IFTTT, so that would be an option, but it would be better to have a straight connection (if possible at all)
https://www.smartalarm.nl/
I have the same alarm still🤔 lack of support and new functions but they have now google home integration.
I also would like to have this integrated in HA aswell.
I managed integrating it by using webhooks and Olisto, it is similar to IFTT, but (still?) free :wink:
Aaah yes did see that too, but is via a non-local way …
But thanks!
Do you have some sort of example i can look at?
I know it is not local, but better than nothing :thinking:
And it looks like Ollisto is that much used (yet), so it is normally quite fast in response :wink:
It uses webhooks…
Ollisto:
HomeAssistant automation:
alias: SmartAlarm Motion detected
description: Uses Olisto
  - platform: webhook
    webhook_id: PIRLRoom
    allowed_methods:
      - POST
      - PUT
    local_only: false
condition:
  - condition: state
      entity_id: group.myfamily
      state: not_home
    alias: Everybody away?
    enabled: true
  - service: notify.mobile_app_my
      title: SmartAlarm
      message: Motion Living room
mode: single
So that is sending info from smartalarm to ha.
But the opposite is also possible, f.e. arm/disarm:
- switch:
    unique_id: smart_alarm
    command_on: curl -k --silent "https://connect.olisto.com/c/Br#%^*%?!€>"
    command_off: curl -k --silent "https://connect.olisto.com/c/Bz#6#7*"
thank, very nice! might set some up with Olisto!
Have tested it loosely with ollisto and it works.
When i leave the home, it arms smartalarm
