Integration with Sunbean WIFI Heated Mattress Pad
I created a pull request to add support for the sunbeam heated mattress pad (home-assistant/core#84869). It looks like the mattress pad and blanket use the same configuration.
Thanks for putting this out there. This was my first adventure into Tuya devices so it helped a lot.
Iā€™ll add that I found the issue with Pre-heat not functioning correctly was due to the first two automations interacting with each other. Whenever ā€œBED_Set Side A input number to match manual heat level changeā€ runs, it triggers ā€œBED_Set heat level for Side Aā€ to also run. When the Pre-heat in enabled it seems to set the heat level value to 10 on the device, which then updates Home Assistant through the second automation, and then the first automation runs and overrides the pre-heat setting.
I didnā€™t need to control the pre-heat time, so instead of adding the ā€œBED_Preheat Side Aā€ automation, I added a condition to the second automation checking if the Pre-heat was off and this prevented home assistant from cancelling pre-heat and losing the ideal heat setting.
I found something quite interesting - note that I do not have a king/queen-size but a full-size pad. My ID numbering is almost the same as listed above using ā€œside Aā€.
I recently changed WIFI and had to reset my mattress pad and the previous local key doesnā€™t work anymore (trial expired). Turns out I can re-register with a different email and got it going again. Because I was redoing everything, I decided to put the extra IDs that I had no idea what they were for as sensors (ID 13, 102, and 103). Here are what I found out about the ā€œsafelyā€ feature:
  1. The interesting one is ID 103 which has a value ā€œUser_Confirmationā€. When I turn the mattress pad on remotely, the value changed to ā€œ45_minutes_beforeā€. The value of ID 103 does not change if I turn the mattress on using the physical keypad.
    However, when I push the physical button for the ā€œsafetyā€ confirmation, the value changes back to ā€œUser_Confirmationā€. I am not sure if I can use HA to force this value to ā€œUser_Confirmationā€ using a select or something. But what I found out next is a perfect workaround to the ā€œsafetyā€ feature (I prefer not to ā€œforceā€ a value to the API and break the system because I have no idea what that ID is for).
  2. It turns out that if you do not use the ā€œPowerā€ (ID 14 in my case) to turn on the mattress remotely, the ID 103 will never change to ā€œ45_minutes_beforeā€ and no user confirmation is required. There are 2 ways to turn the mattress on without using the ā€œpowerā€ switch:
    a) The preheat switch will turn on the mattress without requiring the safety confirmation
    b) Change the power level will also turn the mattress on without requiring the safety confirmation
I will be using the ā€œpower levelā€ as a way to get around the safety ā€œfeatureā€, which makes perfect sense if you use the tuya app. The app developer made an assumption that you cannot use the preheat function nor set the power level in the tuya app until you turn on the power. But then again developing API is a very different story, and they should not assume the flows in their app will be followed when the API is exposed.
I have attached two screenshots from my device - the ā€œinitialā€ state showing ā€œUser_Confirmationā€ message, and the one that showing ā€œ45_minutes_beforeā€ message after I turn the mattress on using the power switch. Hope this help.
edit: I have not yet tested my observation above thoroughly but definitely will in the next few days. I also attached a screenshot after over an hour of turning it on using the power level only.
I think I may be seeing something similar to what you described. Would you mind dropping your automations/YAML, please?
Sorry for the late reply. I just saw the message. I ended up using the ā€œpreheatā€ to remotely turn on the heated pad, then change the heat level. This way, the pad will turn on even if the heat level stays the same as last known value (the last heat level set before powering off).
Here is the YAML code from the visual edtor. I gave up learning the templating because my integration uses sensor temperature to adjust the heat level of my sunbeam but the ā€œnoneā€ / ā€œunavailableā€ status causes much trouble. I use this to turn on my heated pad on a schedule (start and stop time variable set using the helper). It will adjust the heat level throughout the night depending on my bedroom temperature (I set the max at level 5 which is hot enough for me lol).
Note: I have a separate automation to turn the heated pad off at the time set in input_datetime.bed_heater_automtion_end. Both automations are not optimized in any way but they work and much easier for me to update without thinking the edge cases :stuck_out_tongue:
Hope this is what you are looking for.
Post Edit:
  • if you want to use the preheat, you can do that after setting the level, then turn on the preheat one more time. I did not do that in my automation. The first preheat action is to make sure that the heated pad will turn on remotely without requiring user confirmation. It has been working for me in the past week or so.
  • I have a full-size heated pad, not queen/king so I do not have side A and B. Just side A.
  • I also created a ā€œvirtualā€ fan in YAML to put all entities together as a single ā€œheated fanā€ device that can be exported to Alexa so that it can be controlled by voice.
ā€œvirtualā€ entities used:
  • input_datetime.bed_heater_automation_start (when to turn on the heated pad)
  • input_datetime.bed_heater_automation_end (when to turn off the heated pad)
  • input_boolean.bed_heater_automation_enabled (enabling automation)
Tuyaā€™s entities used:
  • switch.bed_heater_power (the on/off switch)
  • select.bed_heater_level (the heat level)
  • switch.bed_heater_preheat (the preheat on/off switch)
alias: Bed Heater Auto On
description: ""
  - platform: state
    entity_id:
      - sensor.bedroom_sensor_temperature
  - platform: time
    at: input_datetime.bed_heater_automation_start
condition:
  - condition: and
    conditions:
      - condition: state
        entity_id: input_boolean.bed_heater_automation_enabled
        state: "on"
      - condition: numeric_state
        entity_id: sensor.bedroom_sensor_temperature
        below: 66
      - condition: or
        conditions:
          - condition: trigger
          - condition: time
            after: input_datetime.bed_heater_automation_start
            before: input_datetime.bed_heater_automation_end
  - if:
      - condition: state
        entity_id: switch.bed_heater_power
        state: "off"
    then:
      - service: switch.turn_on
        data: {}
          entity_id: switch.bed_heater_preheat
  - if:
        above: 63
    then:
      - service: select.select_option
          option: "3"
          entity_id: select.bed_heater_level
    else:
      - if:
            above: 60
        then:
              option: "4"
        else:
              option: "5"
mode: single
https://fccid.io/2ANDL-WBR3 Hereā€™s the FCC information on the tuya chipset in this one.
If Iā€™m reading correctly from other descriptions of the WBR3 online say itā€™s got a RTL8720CF. I donā€™t know if this is pin-compatible with any standard ESP chips, but it does look like itā€™s on the roadmap for libretuya.
Just a thought for anyone willing to wait to have a fully non-tuya integration.
For the people who have integrated this, is it working with localtuya on HACS or the built-in (cloud) Tuya integration?
So, asking for a friend ā€¦ what is / are a ā€˜@Participantā€™. You might consider a bit more sharing and transparency, IMHO.
To your question. I have been using the TinyTuya python library to interact with Sunbeam as a external proxy via MQTT to Home Assistant and Google voice (via Nabu Casa) for 6 months or so. It works, however not ideal. I think I like abstracting the Tuya stuff outside Home Assistant as much as possible until total non-cloud control possible. I would like to replace the Tuya firmware in the Sunbeam to make it 100% local control, however have not explored if possible as yet.
Using the TinyTuya interface ā€˜worksā€™ however requires a level of monitoring that is not realistic for ā€˜realā€™ home automation and ā€˜significant otherā€™ acceptance IMHO.
Good hunting!
im using localtuya on HACS
Yep, local Tuya been flawless for 1 yr+
As some mentioned in this thread, this device is using the WBR3 Tuya module - I followed Blakadderā€™s module replacement guide, and confirmed that I can run Tasmota on the device with an ESP8266 dropped in. The housing can be opened relatively easily by removing the four feet + the screws thereunder - the module is on the reverse side of the PCB.
Iā€™ve sent in a template to the repository, but hereā€™s what Iā€™m using right now:
    "NAME": "Sunbeam Heated Blanket",
    "GPIO": [0, 2272, 0, 2304, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0],
    "FLAG": 0,
    "BASE": 54,
    "CMND": "DeviceName Sunbeam Heated Blanket|TuyaEnumList 1,9|TuyaEnumList 2,9|TuyaEnumList 3,9|TuyaMCU 11,1|TuyaMCU 61,4|TuyaMCU 12,8|TuyaMCU 13,14|TuyaMCU 14,15|TuyaMCU 62,20|TuyaMCU 63,21|TuyaMCU 15,24|TuyaMCU 16,25|TuyaMCU 0,28|TuyaMCU 0,29|WebButton1 Master Power|FriendlyName1 Master Power|WebButton2 Master Preheat|FriendlyName2 Master Preheat|WebButton3 SideA Power|FriendlyName3 SideA Power|WebButton4 SideB Power|FriendlyName4 SideB Power|WebButton5 SideA Preheat|FriendlyName5 SideA Preheat|WebButton6 SideB Preheat|FriendlyName6 SideB Preheat|Rule1 ON TuyaReceived#DpType2Id28 DO Publish2 stat/%topic%/TIMER1 %value% ENDON ON TuyaReceived#DpType2Id29 DO Publish2 stat/%topic%/TIMER2 %value% ENDON|Rule1 1"
I plan on getting it working with HomeAssistant soon, probably using one of the templates shared above as a baseline. If anyone has any examples of configurations that work with Google Assistant, Iā€™d be extra-interested.
e: Learning some things about the timer functionality:
  • Tasmota has a bug in handling timers with values greater than 32767, see Tasmota#18048. A workaround is to use the following rule: Rule1 ON TuyaReceived#DpType2Id28 DO Publish2 stat/%topic%/TIMER1 %value% ENDON ON TuyaReceived#DpType2Id29 DO Publish2 stat/%topic%/TIMER2 %value% ENDON, but the TuyaMCU` setting will need to be changed to unbind the timers. Iā€™ve changed the template above accordingly.
  • The sleep timer DPs (28, 29) are not really read/write, and are actually write-only. This means that the enum is the only way to set these values. Tasmota does not have enough possible enum types, so we can get around this by calling TuyaSend4 directly from HA.
Still working on getting it attached properly to HA.
e2: Got it working well with HA, hereā€™s my configuration. Instructions are below:
# DIY Tasmota Sunbeam Heated Blanket
# Instructions:
# 1. Replace "TASMOTA__TOPIC" with the topic setting in Tasmota.
#    (usually "tasmota_" plus the last six characters in the MAC address).
# 2. Replace "MAC__ADDRESS" with the full MAC address of the Tasmota device.
# 3. Rename this file to "configuration.yaml"
# 4. Make sure the Tasmota integration is turned on, and the device is reporting as expected.
# 5. Drop this in the config/packages/ha-sunbeam-tasmota directory (create it if it doesn't exist.
mqtt:
  select:
    - unique_id: ha-sunbeam-tasmota-autooff-a
      object_id: sidea_autooff
      name: Side A Auto-Off
      icon: mdi:bed-clock
      command_topic: cmnd/TASMOTA__TOPIC/TuyaSend4
      # The "0:00" setting will keep the blanket on.
      command_template: >
        {% if value == "0:00" %}
          26,20
        {% else %}
          26,{{ this.attributes.options.index(value) - 1}}
        {% endif %}
      options:
        - "0:00"
        - "0:30"
        - "1:00"
        - "1:30"
        - "2:00"
        - "2:30"
        - "3:00"
        - "3:30"
        - "4:00"
        - "4:30"
        - "5:00"
        - "5:30"
        - "6:00"
        - "6:30"
        - "7:00"
        - "7:30"
        - "8:00"
        - "8:30"
        - "9:00"
        - "9:30"
        - "10:00"
      state_topic: stat/TASMOTA__TOPIC/TIMER1
      value_template: >
        {% if value|int > 36000 %}
          0:00
        {% else %}
          {{ this.attributes.options[((value|int)/(60 * 60 * 0.5))|round(0,"ceil")|int] }}
        {% endif %}
      device:
        name: Sunbeam Heated Blanket
        connections:
          - [ "mac", "MAC__ADDRESS" ]
    - unique_id: ha-sunbeam-tasmota-autooff-b
      object_id: sideb_autooff
      name: Side B Auto-Off
      icon: mdi:bed-clock
      command_template: >
          27,20
        {% else %}
          27,{{ this.attributes.options.index(value) - 1}}
        {% endif %}
      options:
        - "0:00"
        - "0:30"
        - "1:00"
        - "1:30"
        - "2:00"
        - "2:30"
        - "3:00"
        - "3:30"
        - "4:00"
        - "4:30"
        - "5:00"
        - "5:30"
        - "6:00"
        - "6:30"
        - "7:00"
        - "7:30"
        - "8:00"
        - "8:30"
        - "9:00"
        - "9:30"
        - "10:00"
      state_topic: stat/TASMOTA__TOPIC/TIMER2
      value_template: >
          0:00
        {% else %}
        {% endif %}
      device:
        connections:
    - unique_id: ha-sunbeam-tasmota-temperature-master
      object_id: master_temperature
      name: Master Temperature
      icon: mdi:thermometer-lines
      command_topic: cmnd/TASMOTA__TOPIC/TuyaEnum1
      command_template: >
        {{ value|int - 1}}
      options:
        - "1"
        - "2"
        - "3"
        - "4"
        - "5"
        - "6"
        - "7"
        - "8"
        - "9"
        - "10"
      state_topic: stat/TASMOTA__TOPIC/RESULT
      value_template: >
        {{ value_json.TuyaEnum1|int + 1 }}
      availability_topic: tele/TASMOTA__TOPIC/LWT
      payload_available: "Online"
      payload_not_available: "Offline"
      device:
        connections:
    - unique_id: ha-sunbeam-tasmota-temperature-a
      name: Side A Temperature
      command_topic: cmnd/TASMOTA__TOPIC/TuyaEnum2
      command_template: >
        {{ value|int - 1}}
      options:
        - "1"
        - "2"
        - "3"
        - "4"
        - "5"
        - "6"
        - "7"
        - "8"
        - "9"
        - "10"
      value_template: >
        {{ value_json.TuyaEnum2|int + 1 }}
      device:
        connections:
    - unique_id: ha-sunbeam-tasmota-temperature-b
      name: Side B Temperature
      command_topic: cmnd/TASMOTA__TOPIC/TuyaEnum3
      command_template: >
        {{ value|int - 1}}
      options:
        - "1"
        - "2"
        - "3"
        - "4"
        - "5"
        - "6"
        - "7"
        - "8"
        - "9"
        - "10"
      value_template: >
        {{ value_json.TuyaEnum3|int + 1 }}
      device:
        connections:
Iā€™m using it with localtuya via HACS. Itā€™s connectivity has been solid.
Hereā€™s how Iā€™ve got mine set up with just built-in cards. Nothing toggles the power for the auto-off reasons listed above, so the bottom 3 buttons are for off only, while the top 3 initiate preheat, with a drop down for the current setting. I wish there were a service call to iterate (forwards and backwards) across the values in a select, because thatā€™d enable +/- buttons on each side of a tile with the current value, but this works with no extras.
heated bed ui
type: vertical-stack
cards:
  - show_name: true
    show_icon: false
    type: button
    tap_action:
      action: call-service
      data: {}
        entity_id: switch.master_bedroom_heated_blanket_master_preheat
    entity: switch.master_bedroom_heated_blanket_master_preheat
    icon: mdi:bed-king-outline
    name: Preheat Whole Bed
    icon_height: 30px
    show_state: false
    hold_action:
      action: none
  - type: horizontal-stack
    cards:
      - type: vertical-stack
        cards:
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            entity: switch.master_bedroom_heated_blanket_left_side_preheat
            icon: ''
          - type: entities
            entities:
              - entity: select.master_bedroom_heated_blanket_left_side_heat_level
                icon: ''
                secondary_info: none
            state_color: true
          - show_name: false
            show_icon: true
            type: button
            tap_action:
              service: switch.turn_off
              data: {}
                entity_id: switch.master_bedroom_heated_blanket_left_side_power
            entity: switch.master_bedroom_heated_blanket_left_side_power
            icon: mdi:radiator-off
            show_state: false
            hold_action:
              action: none
        cards:
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            entity: switch.master_bedroom_heated_blanket_right_side_preheat
            icon: ''
          - type: entities
            entities:
              - entity: select.master_bedroom_heated_blanket_right_side_heat_level
                icon: ''
            state_color: true
          - show_name: false
            show_icon: true
            type: button
            tap_action:
              data: {}
                entity_id: switch.master_bedroom_heated_blanket_right_side_power
            entity: switch.master_bedroom_heated_blanket_right_side_power
            show_state: false
            hold_action:
              action: none
  - show_name: true
    show_icon: false
    type: button
    tap_action:
      data: {}
        entity_id: switch.master_bedroom_heated_blanket_master_power
    entity: switch.master_bedroom_heated_blanket_master_power
    name: Turn Blanket Off
    icon: mdi:power-off
    hold_action:
      action: none
Received my Sunbeam heated mattress pad today. However, when attempting to add the device to the Tuya app, I am receiving a ā€œDevice Adding Timeoutā€ error. I have tried this on my mixed 2.4 & 5Ghz network, as well as a separate 2.4Ghz network. This is my 10th Tuya device so I am not really new to the process. Additionally, the device adds right away to the Sunbeam app. Any thoughts?
Hope you can figure it out! I donā€™t have any suggestions, but I didnā€™t have any issue with my mixed 2.4 & 5Ghz network. So maybe the issue is unrelated to your network.
Iā€™m having the same issues adding my blanket that @t.snow3 is reporting. The blanket works fine with the Sunbeam app, but for the life of me I canā€™t get it talking to the Tuya app. it ā€œactsā€ like everything is fine, and then fails at the very end.
I wonder if the blankets (mattress pads) got a new firmware that the generic app doesnā€™t likeā€¦
I know Iā€™m slow to respond, but here is what I have setup. The condition is the only thing I added.
alias: BED_Set Side A input number to match manual heat level change
description: ""
  - platform: device
    device_id: #######
    domain: select
    entity_id: select.side_a_heat_level
    type: current_option_changed
condition:
  - condition: state
    entity_id: switch.side_a_preheat
    state: "off"
  - service: input_number.set_value
      value: "{{ (states.select.side_a_heat_level.state | int) }}"
      entity_id: input_number.side_a_heat_level
mode: single
This one should be the same as what was originally shared, but here it is anyway:
alias: BED_Set heat level for Side A
description: ""
  - platform: state
condition: []
      option: "{{ (states.input_number.side_A_heat_level.state | int) }}"
mode: single
I was having similar issues but spent more time in the tuya dev portal and found out there were some agreements and such that I had to still fill out
ESPHome just added TinyLibre, which can flash Tyuaā€™s custom chips. Has anyone checked out what it would take to convert these pads?
Just got my mattress and it added to tuya just fine and I can control it in there, however in HA under tuya it lists the mattress pad but with no entities, any thoughts on why? I did the download diagnostics and I see commands in the json for it.
