Good morning, after searching everywhere, I couldnt find any help.
My Home Assistant has been running for 2 years without major issue but it seems that time is done. Indeed everytime I make a change in the Integrations panel (add, remove or disable) an integration, the seeting is applied until the next reboot. After that the changes are reverted. Could someone help me with that ? Thank you very much !
Also I forgot to mention that everything else is saved (automations, dashboards…) when changed, it’s only about integrations…
nb :
but since i can’t unload the integration, I dont know how to fix it
Could it come from this ? Again thank you !
edit: i tried disabling, removing, installing different integrations and it seems that all of this trigger the “Recursion limit reached” from storage.py
