Hi all,
Fairly new to all this but I have an issue with the Scrape integration.
Scrape - Home Assistant (home-assistant.io)
In the documentation it shows that there are options available that are not there when you add the integration through the GUI.
I would like the scan_interval to be set to a non-default amount but I can’t see how to achieve this without completely setting up in config.yaml (which I don’t want to do)
Thanks in advance!
