I feel like a total noob here, but I’ll ask anyway.
I’ve installed HomeAssistant in Docker using the official container:
docker pull homeassistant/home-assistant
I followed the docs and everything is up and running on port 8123. Some integrations have been auto-discovered, some other are missing.
One example of integrations that have not been auto-discovered is the Bluesound integration, that appears to be available here: https://www.home-assistant.io/integrations/bluesound/.
It’s nowhere to be found when I search for it in the Lovelace UI:
I can not find a way to add this integration so that my Bluesound devices show up – what am I missing?
I’ve tried editing configuration.yaml
, both with discovery:
and by manually specifying my players IP addresses, as specified in the integration documentation.
I thought that my Docker installation only came with a selection of integrations, and Bluesound might not be the most popular one, so it may require some manual installation. To check it I logged into my Docker container, and it appears that bluesound
does exist there, among other components:
$ docker exec -it home-assistant bash
# Now inside container
$ ls /usr/src/homeassistant/homeassistant/components | grep blue
bluesound
bluetooth_le_tracker
bluetooth_tracker
Seriously, I must be overseeing something, please help me out.
