I’m running Hass OS on an intel nuc directly. Not in a container or anything and have recently purchased an Aeotec Z Stick 7. I used to run all my z-wave devices using a vera hub and the add on but i want to keep it all in one now.
I updated the firmware on the z stick as mentioned in the home assistant manual and all went well. Plugged it into my Nuc, installed z-wave JS add on and integration. The device was detected, created all the security keys etc but every time i go to add a device it just doesn’t detect anything. I’ve tried adding these devices to my old Vera Z wave hub and it pairs up fine so it’s not the device i’m adding.
Any ideas why this could be happening? I read on another forum that there can be some interference with the z stick being so close to the nuc so i bought a USB extension and its at least half a metre away from the nuc but still not help.
I’ve attached a copy of the log from when i try and add a device if this will help.
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· undefined (0x65)
· GetRoutingInfo (0x80)
· UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
· UNKNOWN_FUNC_GET_PRIORITY_ROUTE (0x92)
· UNKNOWN_FUNC_SET_PRIORITY_ROUTE (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· FUNC_ID_SERIAL_API_SLAVE_NODE_INFO (0xa0)
· FUNC_ID_ZW_SEND_SLAVE_NODE_INFO (0xa2)
· FUNC_ID_ZW_SET_SLAVE_LEARN_MODE (0xa4)
· FUNC_ID_ZW_GET_VIRTUAL_NODES (0xa5)
· FUNC_ID_ZW_IS_VIRTUAL_NODE (0xa6)
· BridgeApplicationCommand (0xa8)
· SendDataBridge (0xa9)
· SendDataMulticastBridge (0xab)
· UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
· UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
· UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
· UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
· UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
· UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
· undefined (0xd6)
· undefined (0xd7)
· undefined (0xd8)
· undefined (0xd9)
· undefined (0xda)
· undefined (0xdb)
· undefined (0xdc)
· undefined (0xdd)
· undefined (0xde)
· undefined (0xdf)
· undefined (0xe7)
· undefined (0xe8)
2023-01-30T23:03:04.807Z CNTRLR Performing soft reset...
2023-01-30T23:03:04.820Z CNTRLR Waiting for the controller to reconnect...
2023-01-30T23:03:06.051Z CNTRLR reconnected and restarted
2023-01-30T23:03:06.061Z CNTRLR querying version info...
2023-01-30T23:03:06.078Z CNTRLR received version info:
controller type: Bridge Controller
library version: Z-Wave 7.18
2023-01-30T23:03:06.078Z CNTRLR querying protocol version info...
2023-01-30T23:03:06.103Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 7.18.1
appl. framework build no.: 273
2023-01-30T23:03:06.104Z CNTRLR supported Z-Wave features:
· SmartStart
2023-01-30T23:03:06.104Z CNTRLR querying controller capabilities...
2023-01-30T23:03:06.124Z CNTRLR received controller capabilities:
controller role: primary
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2023-01-30T23:03:06.124Z CNTRLR querying serial API setup capabilities...
2023-01-30T23:03:06.142Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· unknown (0x03)
· SetPowerlevel
· unknown (0x05)
· GetPowerlevel
· GetMaximumPayloadSize
· GetLRMaximumPayloadSize
· unknown (0x12)
· unknown (0x13)
· GetRFRegion
· SetRFRegion
· SetNodeIDType
2023-01-30T23:03:06.143Z CNTRLR Enabling TX status report...
2023-01-30T23:03:06.160Z CNTRLR Enabling TX status report successful...
2023-01-30T23:03:06.160Z CNTRLR Querying configured RF region...
2023-01-30T23:03:06.178Z CNTRLR The controller is using RF region USA
2023-01-30T23:03:06.178Z CNTRLR finding SUC...
2023-01-30T23:03:06.194Z CNTRLR This is the SUC
2023-01-30T23:03:06.194Z CNTRLR querying additional controller information...
2023-01-30T23:03:06.212Z CNTRLR received additional controller information:
Z-Wave API version: 9 (legacy)
Z-Wave chip type: EFR32ZG14 / ZGM130S
node type Controller
controller is the SIS: true
controller supports timers: false
nodes in the network: 1
2023-01-30T23:03:06.238Z CNTRLR [Node 001] Embedded device config loaded
2023-01-30T23:03:06.251Z CNTRLR Interview completed
Starting server on 0.0.0.0:3000
2023-01-30T23:03:06.271Z CNTRLR [Node 001] The node is alive.
2023-01-30T23:03:06.271Z CNTRLR [Node 001] The node is ready to be used
2023-01-30T23:03:06.272Z CNTRLR All nodes are ready to be used
ZwaveJS server listening on 0.0.0.0:3000
New client
New client
Client disconnected
Code 1000:
2023-01-30T23:33:25.879Z CNTRLR Starting inclusion process with strategy Default...
2023-01-30T23:33:25.919Z CNTRLR The controller is now ready to add nodes
2023-01-30T23:34:56.356Z CNTRLR stopping inclusion process...
2023-01-30T23:34:56.389Z CNTRLR The inclusion process was stopped
Here is also my device settings
Appreciate any help i can get.
