jeeftor
(Jeef)
June 3, 2022, 10:52am
202
That sounds about right. That’s why I did the rewrite.
Also I’m thinking switching to the cloud api (todo list) may help reduce timeouts as well because it’s co figured for a long poll option
jeeftor
(Jeef)
June 27, 2022, 5:37pm
203
If anybody’s been waiting for an update → my PR has been sitting in review for a VERY long time…
In any case - since I live at 6700 feet sometimes you need to turn on your fireplace in June!
This was actually really helpful - as the app/HA wasn’t working - checked the error status - reset the fireplace and all is good!
jeeftor
(Jeef)
June 29, 2022, 4:50pm
204
Another PR got accepted… which means:
Fan / Climate are coming up
Soon to be followed by lights
jackflem1
(Jackflem1)
July 8, 2022, 12:28am
206
Seeing these errors after 2022.7.0 upgrade
Logger: intellifire4py
Source: /usr/local/lib/python3.10/site-packages/intellifire4py/intellifire.py:188
First occurred: 2:01:18 PM (15 occurrences)
Last logged: 8:13:02 PM
Unhandled Exception <class ‘asyncio.exceptions.TimeoutError’>
jeeftor
(Jeef)
July 8, 2022, 1:48am
207
Do you have debug mode on? It’s reporting I believe when the module query is timing out for 10 calls in a row.
This unfortunately happens with some frequency when using the local interface. I’ll take a look tomorrow but some of the issues we see with the module are connected to this timeout I believe.
jackflem1
(Jackflem1)
July 8, 2022, 10:24am
208
Don’t have debug on. Never saw this error before the July update.
I think this just the timeout errors being reported with a new format from the new version of python that is in the July release.
Nice little outage today from Intellifire. Cannot wait to be able to ditch the cloud entirely…
Dear IntelliFire App User, We are currently experiencing an IntelliFire app system outage that will affect app and voice control of your fireplace or stove. We are working as quickly as possible to resolve the issue and will notify you when it is fixed. For now, please use other controls to run your gas fireplace or stove.
jackflem1
(Jackflem1)
July 27, 2022, 5:37pm
210
Intellifire system is still down - 2 days now…
jackflem1
(Jackflem1)
August 9, 2022, 12:44pm
211
Anyone else see their fireplace turn on and off randomly. I had it happen over a year ago once that I know about and then it just happen the other night. It’s a very short on then off!
jeeftor
(Jeef)
August 9, 2022, 2:08pm
212
Mine was turning on/off but I think the kids were talking Alexa to it so I turned off the manual switch recently.
Also this is really awesome HA picked it up!
jackflem1
(Jackflem1)
August 12, 2022, 11:14am
213
Got this new error
Source: /usr/local/lib/python3.10/site-packages/intellifire4py/intellifire.py:171
First occurred: 7:02:31 AM (1 occurrences)
Last logged: 7:02:31 AM
Error decoding JSON: [<bound method ClientResponse.text of <ClientResponse(http://192.168.86.14/poll ) [200 Ok]> <CIMultiDictProxy(‘Connection’: ‘close’, ‘Server’: ‘IFTwifi 0.3.1+hw2’, ‘Access-Control-Allow-Origin’: ‘*’)> >]
jeeftor
(Jeef)
August 17, 2022, 3:43am
214
Hmm. Not super useful output. My guess would be it died mid response.
Curious if there has been any progress on light integration. Thanks!
jackflem1
(Jackflem1)
August 26, 2022, 4:17pm
216
Also interested in the fan speed integration?
jeeftor
(Jeef)
August 26, 2022, 5:29pm
217
It’s been sitting in pr for a long while.
home-assistant:dev
← jeeftor:intellifire_fan
opened 04:44PM - 29 Jun 22 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Add Fan support to IntelliFire with 4 speeds: 1,2,3,4
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/23237
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [x] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [x] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
jeeftor
(Jeef)
August 29, 2022, 11:23am
218
And … now I’m on travel for a week just as they finally got back to it … alas
gibber9583
(Gibber9583)
September 6, 2022, 3:15pm
219
Hey its progress!
If these last few items can get into the release branches in time for the season I’m gonna be very happy
jackflem1
(Jackflem1)
September 7, 2022, 9:52pm
221
Jeff, where do you stand with the lights on/off?
I just installed 2022.9 and the fan control is not there.
