I’d like to integrate this solar diverter. The device (details at https://www.intelligent-immersion.co.uk/ ) can be accessed using HTTP and returns an XML document. http://ip.address/ii3.xml returns something like
<response>
<script/>
<immersionpower>0</immersionpower>
<immersionpowerm>0</immersionpowerm>
<avggridexport>-695</avggridexport>
<avggridexportm>-693</avggridexportm>
<timedoverride>2</timedoverride>
<tmro>129</tmro>
<switchstatus>2</switchstatus>
<relaymode>192</relaymode>
<relayoffimport>0</relayoffimport>
<relayonthreshold>2500</relayonthreshold>
<relaytimeforthreshold>1200</relaytimeforthreshold>
<powerminimum>50</powerminimum>
<immersionsize>2700</immersionsize>
<cloud>0</cloud>
<numberoutputs>8</numberoutputs>
<relaystatus>0</relaystatus>
<novram>0</novram>
<wifiswitch>0</wifiswitch>
<wifirelaymode>0</wifirelaymode>
<wifirelayoffimport>255</wifirelayoffimport>
<wifirelayonthreshold>255</wifirelayonthreshold>
<wifirelaytimeforthreshold>255</wifirelaytimeforthreshold>
<wifipowerminimum>255</wifipowerminimum>
<wifiimmersionsize>255</wifiimmersionsize>
<wificloud>255</wificloud>
<wifinumberoutputs>8</wifinumberoutputs>
<wifirelay>0</wifirelay>
<wifinovram>0</wifinovram>
<wifict>255</wifict>
<cloudstatus>3</cloudstatus>
<serverreset>7:20</serverreset>
<ct2>0</ct2>
<ct2m>6</ct2m>
<ct3>0</ct3>
<ct3m>0</ct3m>
<houseload>695</houseload>
<availpower>0</availpower>
<boostminutes>0</boostminutes>
<overriderunning>0</overriderunning>
<outputs>0 0 0 0 0 0 0 0</outputs>
<inputs>none</inputs>
<serverip>0.0.0.0</serverip>
<medtermge>0</medtermge>
<relaytime>20:00</relaytime>
<arraychksum>85</arraychksum>
</response>
To make changes pass parameters via GET ie of the form //ii3.local/ii3.xml?xx=a&yy=b&zz=c
parameters currently available
Parameter xx a
override switch sw 0 = local 1 = off 2 = auto 3 = on
relay mode rm 0 = local 224 = none 192 = second load proportional 160 = second load switched 96 = circulation pump
relay rl 0 = off 1 = on
note the relay mode must be set to 224 ie none before the relay will operate.
HACS-bank
(Jay Tee)
September 15, 2021, 7:28am
2
I am now reading the device successfully using the REST integration. I have not yet looked at issuing commands to it.
peng72
September 13, 2022, 7:55pm
3
Hi HAC S-bank,
I also have one of these units and I am interested in how you did this? I am a bit new to HA and Rest. I think I have something that might work but although it checks out config wise I don’t get any sensors from it.
HACS-bank
(Jay Tee)
September 22, 2022, 7:33am
4
Here is my REST sensor definition, which I made by editing the XML response from accessing the unit with a browser.
I put it in a separate file and used “include” in the main configuration file.
HACS-bank
(Jay Tee)
October 28, 2023, 11:36am
5
Here is my current rest: definition for the Intelligent Immersion I3 solar diverter
- scan_interval: 10
resource: http://i2w.local/ii3.xml
- name: I3
unique_id: i3w
json_attributes_path: "$.response"
value_template: "OK"
- name: Immersion Power
unique_id: immersionpower
json_attributes: "immersionpower"
value_template: '{{ value_json.response.immersionpower }}'
device_class: "power"
unit_of_measurement: "W"
- name: "Immersion Power (mean)"
unique_id: immersionpowerm
value_template: '{{ value_json.response.immersionpowerm }}'
- name: "Avg Grid Export"
unique_id: avggridexport
value_template: '{{ value_json.response.avggridexport }}'
- name: "Avg Grid Export (mean)"
unique_id: avggridexportm
value_template: '{{ value_json.response.avggridexportm }}'
- name: "CT2"
unique_id: ct2
value_template: '{{ value_json.response.ct2 }}'
- name: "CT2 (mean)"
unique_id: ct2m
value_template: '{{ value_json.response.ct2m }}'
- name: "CT3"
unique_id: ct3
value_template: '{{ value_json.response.ct3 }}'
- name: "CT3 (mean)"
unique_id: ct3m
value_template: '{{ value_json.response.ct3m }}'
- name: "House load"
unique_id: houseload
value_template: '{{ value_json.response.houseload }}'
- name: "Available power"
unique_id: availpower
value_template: '{{ value_json.response.availpower }}'
- name: "boostminutes"
unique_id: boostminutes
value_template: '{{ value_json.response.boostminutes }}'
device_class: "duration"
unit_of_measurement: "min"
# - "timedoverride"
# - "tmro"
# - "relaymode"
# - "relaystatus"
# - "switchstatus"
# - "cloudstatus"
# - "serverreset"
# - "overriderunning"
# - "medtermge"
