Intent variables
I’m trying to add a voice assistant intent to add items to my shopping list. My current configuration:
config/custom_sentences/en/shopping.yaml:
language: "en"
intents:
  ShoppingAdd:
      - sentences:
          - "add"
intent_script:
  ShoppingAdd:
    speech:
      text: "added"
So far so good, this works (left out action as it’s not necessary for now).
But when I try to add a variable to the intent by modifying "add" to "add {name}", "add {{name}}", "add <name>" etc i get the response intent-failed:
language: "en"
intents:
  ShoppingAdd:
      - sentences:
          - "add {name}"
intent_script:
  ShoppingAdd:
    speech:
      text: "added {{name}}"
did you see Calling shopping_list.add_item service from HA Assist - #6 by grzech1983 ?
I got it working by pre-populating my usual shopping items in the yaml (used python to build the yaml from a simple list)
Any way to do it without pre-populating a list? I would rather have an actual variable instead of a list of defined values.
As seen here, this is not currently possible by the default intent language, but it will most likely be supported in the future.
However, there’s a reasonable workaround: this integration provides a custom agent with regex support, falling back to the default one if no match is made.
Looks like this is coming : Add HassShoppingListAddItem intent + wildcards by synesthesiam · Pull Request #1466 · home-assistant/intents · GitHub
