Hi
I was thinking to use a Google Cast device to display Lovelace interface on a display but how do I interact with Lovelace in such configuration ?
Thanks for explanations
Vincèn
Hi
Vincèn
What display are you thinking of using? A Google Nest Hub, or a standard TV with a Chromecast attached?
If Nest Hub, it will work natively. If TV without a touch screen, I’m afraid you can’t interact with it
Will be a standard monitor I have seen that Chromecast now has a remote supplied with it ! Can it be used to interact with Lovelace ?
I’ve got no idea but my initial thoughs would be:
@lolouk44 Sorry for late answer but I had to test on site and I confirm you that Chromecast is for sure not a viable solution to display Lovelace dashboard ! All the more it crashes straight if you have some livefeeds from cameras in your Lovelace layout
