Problem :
When you have an alarm system opening a window or lowering a blind could make the alarm ring.
Actual solution :
Per every blind/window/switch build a template based in the same data of the actual object and insert a script to do the check BEFORE actually open it.
Desired possible solutions :
- Change the call globally to insert default behaviour (disable sensor, disable alarm, don’t open, play an audio warning etc.)
- insert sensor-object relationship and define a behaviour
- both
