Interesting high CPU load
I ran into an interesting situation.
A friend of mine has problems with the Home Assistant on his Pi3. Something went really wrong the last couple of day and I suspected HW issues. So he brought his Pi3 with the SD Card to me and I just plugged it in to see how it behaves.
My network is setup for 192.168.1.x and I have 2 instances running:
  • one NUC for the main instance
  • one VM in Virtual Box with HassOS to play with anything HA related and the latest updates.
His installation was setup for a fixed IP: 192.168.0.52.
I had attached a Keyboard and Display to the Pi3 and had a look around the error logs when suddenly I got a notification that the NUC is overloading.
This is a image with the top on both machines.
I took a look on the Load graph and it went up around the time I plugged in the Pi.
Then I had a look on my router on the connections lists but I did not see any 192.168.0.52 traffic.
Hmm… this cannot be a coincidence. So I unplugged the network cable on the PI and immediately both machines went to normal. I plugged in the cable and I had the confirmation that it was the PI causing this behavior.
How can this be explained?
Thank you.
