where do you get the burner status from? same as the bar’s from the pump, boiler and burner?
I found the pump and tap water but can’t do anything with them, or I didn’t find out yet how.
In the thermostat I only see the status verwarmen (heating) even if the heating is off.
I also have boiler, that one gives a status back:
so if you can help me out a bit here on to get the data that will be great
zxdavb
(David Bonnes)
December 27, 2020, 3:53pm
42
This is the lovelace yaml:
- title: Boiler State
path: boiler-state
badges:
- entity: binary_sensor.burner
- entity: binary_sensor.incomfort_failed
- entity: binary_sensor.pump
- entity: sensor.incomfort_cv_pressure
- entity: sensor.incomfort_cv_temp
- entity: sensor.incomfort_tap_temp
cards:
- type: entities
entities:
- entity: sensor.boiler
- entity: water_heater.incomfort
- entity: water_heater.boiler_h_w
- type: picture-entity
entity: camera.foscam_camera
- type: history-graph
entities:
hours_to_show: 1
refresh_interval: 0
title: 1 hour(s)
zxdavb
(David Bonnes)
December 27, 2020, 3:55pm
43
… and here is a portion of my configuration.yaml file:
incomfort:
host: 192.168.0.12
sensors:
boiler:
friendly_name: "Boiler"
value_template: "{{ state_attr('water_heater.incomfort', 'display_text') }}"
binary_sensor:
sensors:
pump:
friendly_name: "Pump"
value_template: "{{ state_attr('sensor.incomfort_cv_temp', 'is_pumping') }}"
burner:
friendly_name: "Burner"
value_template: "{{ state_attr('water_heater.incomfort', 'is_burning') }}"
zxdavb
(David Bonnes)
December 27, 2020, 4:11pm
44
This is the relevant portion of code, which would behave as you describe:
@property
def hvac_mode(self) -> str:
"""Return hvac operation ie. heat, cool mode."""
return HVAC_MODE_HEAT
I wrote the integration, but never had a system with a bound thermostat to work with. This feature could be fleshed out, but - if I was to do it - I’d need someone to help.
You could start with:
logger:
default: critical
logs:
homeassistant.components.incomfort: debug
… and look for the lines corresponding to:
@property
def device_state_attributes(self) -> Dict[str, Any]:
"""Return the device state attributes."""
return {"status": self._room.status}
Many thanks for your fast response, going to play around and let you know the results…
I think I know where the difference is between yours and mines, my Thermostat is a opentherm one, and not just on and off. ( Honeywell Round Modulation T87M2018)
I will set this for:
logger:
default: critical
logs:
I installed the Incomfort gateway (by simply adding the few lines to the configuration.yaml file).
Till now I haven’t been succesful to get the entities to show up, only thing I get in the logs is this:
Update of water_heater.incomfort is taking over 10 seconds
Any thoughts? I checked the username and password, got those right
