I’m really new to Home Assistant, but it’s really great what you can do with it. I’ve already setup a lot of automations and devices in it and it works like a charm.
Unfortunately I’ve a issue with the installation. I cannot restart Home Assistant, without booting the whole pi.
I get an error, that the Integration home is missing:
ERROR (MainThread) [homeassistant.components.homeassistant] The system cannot reload because the configuration is not valid: Integration error: home - Integration ‘home’ not found.
Everything else is working. This is only a little disturbing. Does someone had the same error?
I cannot find an integration named home. Also I cannot find a reference in the files pointing to this integration.
