Hills Reliance R128 with Commnav Index Error List index out of range
I have installed ultrasync from Hacs and get an error in the logfile
2021-01-28 13:55:18 ERROR (MainThread) [custom_components.ultrasync.coordinator] Unexpected error fetching ultrasync data: list index out of range
File “/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/helpers/update_coordinator.py”, line 144, in async_refresh
self.data = await self._async_update_data()
File “/var/snap/home-assistant-snap/123/custom_components/ultrasync/coordinator.py”, line 108, in _async_update_data
return await self.hass.async_add_executor_job(_update_data)
File “/usr/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “/var/snap/home-assistant-snap/123/custom_components/ultrasync/coordinator.py”, line 53, in _update_data
details = self.hub.details(max_age_sec=0)
File “/root/snap/home-assistant-snap/123/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 578, in details
if not self.update(max_age_sec=max_age_sec):
File “/root/snap/home-assistant-snap/123/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 563, in update
if not self._sequence():
File “/root/snap/home-assistant-snap/123/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 1498, in sequence
return getattr(self, ’ {}_sequence’.format(self.vendor))()
File “/root/snap/home-assistant-snap/123/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 1637, in _comnav_sequence
if area[‘sequence’] != a_seq[bank]:
IndexError: list index out of range
2021-01-28 13:55:18 WARNING (MainThread) [homeassistant.config_entries] Config entry for ultrasync not ready yet. Retrying in 80 seconds
when i run the utility I get the same error
~/.local/bin$ ./ultrasync -c ~/.config/ultrasync -w
2021-01-28 14:36:32 [001] Front Door[R : Ready
2021-01-28 14:36:32 [001] Dining Room Garage[R : Ready
2021-01-28 14:36:32 [001] Garage to Laundry : Ready
2021-01-28 14:36:32 [001] Upstairs Rumpus[M] : Ready
2021-01-28 14:36:32 [001] Bedroom 2,3,4 [M] : Ready
2021-01-28 14:36:32 [001] Dining Room[M] : Ready
2021-01-28 14:36:32 [001] Basement[M] : Ready
2021-01-28 14:36:32 [001] Under House Door[R] : Ready
2021-01-28 14:36:32 [001] Large Garage Door[R] : Ready
2021-01-28 14:36:32 [001] Small Garage Door[R] : Ready
2021-01-28 14:36:32 [001] Sewing Room[M] : Ready
2021-01-28 14:36:32 [001] Loft Door [R] : Ready
2021-01-28 14:36:32 [001] Basement Slide : Ready
2021-01-28 14:36:32 [001] Family Room Slide : Ready
2021-01-28 14:36:32 [001] Laundry Door[R] : Ready
2021-01-28 14:36:32 [001] Master Bedroom[M] : Ready
2021-01-28 14:36:32 [001] Dining Room Slide W : Ready
2021-01-28 14:36:32 [001] Dining Room Slide E : Ready
2021-01-28 14:36:32 [208] Inside House : Ready
2021-01-28 14:36:32 [000] Garage : Ready
File “./ultrasync”, line 8, in
sys.exit(main())
File “/usr/lib/python3/dist-packages/click/core.py”, line 764, in call
return self.main(*args, **kwargs)
File “/usr/lib/python3/dist-packages/click/core.py”, line 717, in main
rv = self.invoke(ctx)
File “/usr/lib/python3/dist-packages/click/core.py”, line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File “/usr/lib/python3/dist-packages/click/core.py”, line 555, in invoke
return callback(*args, **kwargs)
File “/home/halldave/.local/lib/python3.8/site-packages/ultrasync/cli.py”, line 199, in main
results = usync.details()
File “/home/halldave/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 578, in details
File “/home/halldave/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 563, in update
File “/home/halldave/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 1498, in sequence
File “/home/halldave/.local/lib/python3.8/site-packages/ultrasync/main.py”, line 1637, in _comnav_sequence
I use Ultrasync as an app on the phone, and logging in directly to the comnav web app , the card is plugged into a Hills Reliance 128 zone panel. even though only 18 zones are configured
i have attached my debug file
20210128144216.ultrasync-dump.zip
