I have a Airthings Wave+ added to HA and reporting values.
The issue is that the data only shows in the dashboard sporadically. Screenshot attached.
Wondering if there is a solution to this problem?
If not, is there a way gather the data and always present the most recent values instead of “unavailable”?
Here is what the data looks like.
Not fixing the intermittent data is ok, if I can get the dashboard to show the most recent data instead of “Unavailable”.
I am experiencing the same issue. Annoyingly, the AirThings app does fill up the gaps. It seems, Home assistant only reads the current value from the sensor, and logs those readings. So, if the connection is broken, there will be a gap in the history. Contrary to that, the AirThings app retrieves historical data from the sensor, so there are no gaps. And when you launch the app during no-connection, it shows the most recent reading.
