I successfully connected my gmail account to home-assistant using the imap integration with the following configuration.yaml
- platform: imap
server: imap.gmail.com
port: 993
username: [email protected]
password: xxxxxxxxx [App Password]
search: FROM <[email protected]>, SUBJECT <Work>
Everything works great, however I have noted intermittent delays from the mailhook entity.
Taking a look at the log files I note the warnings
01:00 Lost imap.gmail.com (will attempt to reconnect)
01:30 Lost imap.gmail.com (will attempt to reconnect)
02:00 Lost imap.gmail.com (will attempt to reconnect)
this warning appears consistently every 30minutes. Adding a DEBUG logger for aioimaplib.aioimaplib shows home assistant immediate reconnecting to the gmail server after every disconnection. So I assume this is correct operation with each imap IDLE connection timing out after 30minutes according to the imap standard.
However I anecdotally note that an e-mail received within 0-~15minutes of a timeout is almost instantly received by the mailhook (within a few seconds), but an e-mail received ~15-30minutes after a timeout is not registered immediately. It is lost and the mailhook will only register on the next timeout when the IDLE connection is re-initialised. This results in ~10minute delay depending on when the e-mail is received versus the HA IDLE connection cycle.
There is no debug information in the HA log file that indicates a problem. Simply put the log file just shows that HA doesn’t receive an IDLE notification.
The g-mail android app, which I presume is also using IMAP IDLE see’s all mails instantaneously when connected to the same internet connection as HA. So I struggle to see that this is a server/network problem.
Can anyone replicate these results or have any idea’s what is going on here ?
