This one has been driving me nuts for the last few days, hopefully, someone notices something I haven’t.
I run this script to set thermostat values for cooling and heating. it works only the first time the script is run, and then not again until I refresh scripts, or save it again with no changes.
Error log:
Logger: homeassistant.components.script.downstairs_climate_test
Source: components/zwave_js/device_action.py:244
Integration: Script (documentation, issues)
First occurred: March 17, 2022, 8:57:30 AM (12 occurrences)
Last logged: 9:49:02 AM
Downstairs climate set: Choose at step 1: choice 1: Error executing script. Unexpected error for device at pos 1: 'type'
Downstairs climate set: Error executing script. Unexpected error for choose at pos 1: 'type'
Downstairs climate set: Choose at step 1: choice 2: Error executing script. Unexpected error for device at pos 1: 'type'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 367, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 578, in _async_device_step
await device_action.async_call_action_from_config(
File "/usr/src/homeassistant/homeassistant/components/device_automation/action.py", line 68, in async_call_action_from_config
await platform.async_call_action_from_config(hass, config, variables, context)
File "/usr/src/homeassistant/homeassistant/components/zwave_js/device_action.py", line 244, in async_call_action_from_config
action_type = service = config.pop(CONF_TYPE)
KeyError: 'type'
Script
alias: Downstairs climate set
sequence:
- choose:
- conditions:
- condition: state
entity_id: input_boolean.sleep
state: 'on'
sequence:
- device_id: 4030df90ad00ed2d6358f379b5f9e597
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '65'
property_key: '1'
endpoint: '0'
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '71'
property_key: '2'
endpoint: '0'
- conditions:
- condition: state
entity_id: input_boolean.awake
state: 'on'
sequence:
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '76'
property_key: '2'
endpoint: '0'
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '72'
property_key: '1'
endpoint: '0'
- conditions:
- condition: state
entity_id: input_boolean.evening
state: 'on'
sequence:
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '73'
property_key: '2'
endpoint: '0'
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '68'
property_key: '1'
endpoint: '0'
- conditions:
- condition: state
entity_id: input_boolean.away
state: 'on'
sequence:
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '65'
property_key: '1'
endpoint: '0'
domain: zwave_js
type: set_value
command_class: 67
property: setpoint
value: '80'
property_key: '2'
endpoint: '0'
default: []
mode: restart
