when loading web UI of any addon i get this error:
# 500 Internal Server Error
Server got itself in trouble
console in browser:
GET http://homeassistant:8123/api/hassio_ingress/... 500 (Internal Server Error)
Supervisor log:
ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/sentry_sdk/integrations/aiohttp.py", line 139, in sentry_app_handle
reraise(*_capture_exception())
File "/usr/local/lib/python3.12/site-packages/sentry_sdk/utils.py", line 1640, in reraise
raise value
File "/usr/local/lib/python3.12/site-packages/sentry_sdk/integrations/aiohttp.py", line 129, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 189, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 205, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 224, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 283, in core_proxy
File "/usr/src/supervisor/supervisor/api/ingress.py", line 164, in handler
return await self._handle_request(request, addon, path, session_data)
File "/usr/src/supervisor/supervisor/api/ingress.py", line 240, in _handle_request
async with self.sys_websession.request(
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1197, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 606, in _request
resp = await req.send(conn)
File "/usr/local/lib/python3.12/site-packages/aiohttp/client_reqrep.py", line 723, in send
await writer.write_headers(status_line, self.headers)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 129, in write_headers
buf = _serialize_headers(status_line, headers)
File "aiohttp/_http_writer.pyx", line 132, in aiohttp._http_writer._serialize_headers
_safe_header(to_str(val))
File "aiohttp/_http_writer.pyx", line 116, in aiohttp._http_writer._safe_header
raise ValueError(
ValueError: Newline or carriage return character detected in HTTP status message or header. This is a potential security issue.
configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
frontend:
themes: !include_dir_merge_named themes
lovelace:
resources:
- url: /local/custom-lovelace/button-card.js
type: module
- url: /local/custom-lovelace/card-mod.js
type: module
- url: /local/custom-lovelace/digital-clock.js
type: module
- url: /local/custom-lovelace/kiosk-mode.js
type: module
- url: /local/community/lovelace-mushroom/mushroom.js
type: module
- url: /local/community/mini-media-player/mini-media-player-bundle.js
type: module
- url: /local/community/lovelace-header-cards/lovelace-header-cards.js
type: module
- url: /local/community/lovelace-card-mod/card-mod.js
type: module
- url: /local/community/lovelace-wallpanel/wallpanel.js
type: module
wake_on_lan:
switch:
- platform: wake_on_lan
mac: *mac*
host: *ip*
turn_off:
service: hassio.addon_stdin
addon: core_rpc_shutdown
input: inputpc
I’ve had this problem for about a year now, so it’s not the HASS version. I didn’t need to deal with it, because the addons I used were either set only via configuration or I used something else instead (file editor => ssh via putty), until now when I need it for zigbee2mqtt (I can’t use z2m frontend when using HASS OS)
I read a lot of discussions on a similar topic but nothing.
I tried:
- empty configuration.yaml
- disable each addon
- turn off integrations (mainly those that bridged for third-party devices or were from apple, because I found that they caused this to someone)
- I changed the main http address from the original homeassistant
I don’t have http set in configuration.yaml or anything that could cause this (I think. I tried removing WOL).
This problem just appeared on its own one day, I didn’t change or adjust anything. I thought it was some poorly done update of some integration/addon/hass, so I thought it would disappear one day by itself, it didn’t.
Any idea?
