"Internal" time wrong
the sensor section. Just don’t include the line sensor: if you already have a sensor section.
Ok, I reated the sensor in configuration.yaml and have it in lovelace. but is this what you mean:
c
I wanted just my local time that show that last tripped time as a “second” below the sensor…
That’s not a normal entities card. That appears to be a custom card. You’ll have to stick to the built in cards to see ‘x minutes ago’. If you want the actual time, you’ll need to convert to local.
I used this initially:
but then I used this:
But the last time the sensor was tripped was 20:22, thus for me 2 hours ago…
it doesn’t round.
so you mean in 4 minutes from now, at my time 22:22 it will say “2 hours ago”?
EDIT: yes it does:
yep, that’s what will happen.
Ok thank you for your help.
As a moderate user I must say that this is not very handy/understandable/user friendly/clear/whatever comes to that :-). I just want to see “my time” stuff in hass and not a UTC timezone that for me in this location make no real sense… I think this must be aware to the “awesome guys” that make hass?
I would really like to see events and tripped times to my timezone. That not a dumb question is it?
I understand where you’re coming from, but it’s only confusing because of the way that your device is implemented. Anyone who want’s a special time displayed in the interface from a device goes through this and there is 9000 different ways people want to view their time. Some people want AM PM, some people only want minutes, some people want it spelled out… see where this is going?
For example, my motion sensors do not have a special attribute called ‘last_tripped_time’. They just turn on and off. HA handles the times by using the last_updated and last_changed state object properties. (giving you the ability to use the last_changed secondary row). Your sensor is unique because it doesn’t do that. Apparently when your sensor trips, it doesn’t send an update to the main state, effectively making last_changed or last_updated useless.
Sorry, I don’t see where you are going :-). time is time, nothing fancy is it? I don’t care about AM/PM, written or sung, but I DO care about the correct ZONE. Nevertheless, thank you and I hope it will be picked up in the future.
Yes, but you seem to not understand. The more-info page is showing you unaltered attributes. It (home assistant) does not know it’s a time. So it keeps it unaltered. That’s up to the user to make use of the attribute.
If that is coming straight from your device, then your device needs to use the local timezone. And if thats something that you can’t set, then you can make a request to the integration to put that time in local timezone. Or do what everyone else does and convert the time. There’s a number of threads that cover how to do that. Here’s one:
Ok I see now that I don’t know what I don’t know. I’ll read on. thanks again!
Hi, another question regarding this topic…
what if I wanted this:
Tried this:
    sensors:
      car_last_tripped:
        friendly_name: "Last Motion in BMW"
        value_template: "{{ state_attr('switch.motion_sensor_5_1493', 'last_tripped_time') }}"
        device_class: timestamp
      hal_voorkant_afdak_last_tripped:
        friendly_name: "Last Motion Voordeur"
        value_template: "{{ state_attr('binary_sensor.sensor_hal_voorkant_beweging', 'last-changed') }}"
But clearly I have not yaml knowledge :frowning:
you must have an error there in the logs… use last_changed instead, and use it like this:
{{ states.binary_sensor.sensor_hal_voorkant_beweging.last_changed }}
you cant template last_changed using the states() method
yes, seems to work now, thank you!
sure, welcome.
you should understand why though, so read up on this: https://www.home-assistant.io/docs/configuration/state_object/
last_changed isn’t an attributes you can call using state_attr()
Hi, read it. but I do not understand what you mean with
using state_attr() you can reference all attributes of the state.
in your case eg:
states.binary_sensor.sensor_hal_voorkant_beweging.attributes.name
states.binary_sensor.sensor_hal_voorkant_beweging.attributes.icon
which you can also write as
state_attr('binary_sensor.sensor_hal_voorkant_beweging','name')
this is also explained here: https://www.home-assistant.io/docs/configuration/templating/#states
be sure to read the yellow Warning bit, as it will help you write safer templates.
if you want to see which attributes are available for you entity, just throw this at the template editor:
{{states.binary_sensor.sensor_hal_voorkant_beweging.attributes}}
you’ll notice ‘last_changed’ isnt listed. because it is no ‘attribute’.
On a RaspPi 3, HassOS 3.13
{{ utcnow() }}
{{ now() }}
{{ utcnow().astimezone() }}
{{ now().astimezone() }}
{{ utcnow().tzinfo }}
{{ now().tzinfo }}
{{ now().astimezone().tzinfo }}
I get
2020-05-19 01:53:12.396476+00:00
2020-05-18 20:53:12.396624-05:00
2020-05-19 01:53:12.396790+00:00
2020-05-19 01:53:12.398530+00:00
UTC
America/Chicago
UTC
Any idea why the astimezone() are all messed up?
