check out this
Hello Everybody!
Looks like I have a similar issue with time settings. I think you are all running in circles not finding the correct issue.
I say this because:
I am running home assistant supervised in an esxi VM. Installed using 3.13 vmdk image.
Since I installed it a few days ago, I have had a lot of problems, by losing access to the server. I saw it was losing its ip address.
So after reading a lot of topics, I found that the timestamps in supervisor logs are of by 3 hours.
This time delay will F*** up the dhcp renewal from my router (pfsense vm) and after the minimum lease time of 2 hours, the home assistant machine loses its IP and I have to power cycle it. Simple reset will not solve the issue.
Now, I would like to ask you if there is any way to correct this issue. It is driving me crazy, and until now I did not manage to find a way to set the supervisor time/timezone.
Thank you,
And here is my original topic on this forum: Hassio on esxi losing IP address - HA supervised
And here is the issue on Github: https://github.com/home-assistant/operating-system/issues/684
Similar problem here??
{{ now() }}
{{ now().astimezone() }}
{{ utcnow().astimezone() }}
{{ now().now() }}
{{ now().today() }}
{{ now().utcnow() }}
{{ utcnow() }}
{{ now().tzinfo }}
{{ now().astimezone().tzinfo }}
{{ utcnow().tzinfo }}
2022-11-12 15:12:40.501943+00:00
2022-11-12 09:12:40.501943-06:00
2022-11-12 09:12:40.502947
2022-11-12 15:12:40.502946
2022-11-12 15:12:40.502946+00:00
UTC
Central Standard Time
UTC
System Health
Version | core-2022.2.3 |
Installation Type | Unknown |
Development | false |
Supervisor | false |
Docker | false |
Virtual Environment | false |
Python Version | 3.9.10 |
Operating System Family | Windows |
Operating System Version | 8.1 |
CPU Architecture | AMD64 |
Timezone | America/Chicago |
This automation is going off at 8AM UTC, not 8AM CDT:
- id: ‘1651526240883’
alias: Time - Fountain On
description: Turn on the fountain
trigger:- platform: time
at: 08:00:00
condition: []
action: - type: turn_on
device_id: e96adb89d8978094879aca474a5f009a
entity_id: switch.on_off_outlet_45_c4_8f_bottom
domain: switch
mode: single
- platform: time
seems like something isn’t correct?
