Hello! I’m new to HA; hope this is the right place to ask for help.
I installed the generic HA image on an old Toshiba Laptop. It runs great, but Wi-Fi does not work. I really want to use it, but it’s not detected.
I tried Ubuntu 21.10 and Wi-Fi works out of the box. Fn + F12 toggles Wi-Fi and a red LED indicator on/off, so I made sure it is turned on.
- ‘netstat -i’ shows: wlp1s0, enp2s0 and lo
In HA all terminal commands show the Ethernet card, but the Wireless card is not detected. The key combo also works here and it’s turned on.
- ‘ha network info’ shows only Ethernet
- ‘ha hardware info’ shows this (pastebin)
- ‘nestat -i’ shows: docker0, enp2s0, hassio, lo and 6 times ‘veth____’
- ‘nmcli radio’ shows everything is enabled
- ‘nmcli device wifi rescan’ finds no device
- ‘nmcli con show’ shows the connection I set up in the config file (and the Ethernet connection)
I got more information while running Ubuntu:
- Wi-Fi card: Qualcomm Atheros AR9565
- Driver: ath9k
Edit: I also tried running HA as a VM in Ubuntu and bridging WiFi. It works, but it gets disconnected after 30-40 minutes for some reason.
I guess HA doesn’t have the driver I need? I don’t really know how drivers work in Linux. Is it possible to install it? Can I copy some files from Ubuntu to enable it?
I appreciate any piece of advice and I hope this thread will be helpful to other people too.
