Is possible to integrate in the attribute the current latitude and longitude? so is possible to to track it on a map
thanks
thanks
Would be possibleā¦the problem is that you need to do some heavy scrolling to get your home zone in a visible scale.
I dont want to add it to home assistant mapā¦ but I want to track the latidude and longitudine with the camera: component in home assistant an example is owntracks and gmaps integration
Can you please take a look at?
And comment or give feedback on the PR if needed. Thanks.
Thanks for the info.
So if show_on_map: True I can see ISS on the hass integrated MAP right?
If the show_on_map: false I can see the long and lat in the attributes?
yes
Yes, both values are added to the state attributes.
thatās awesomā¦ Iāll wait to test it when it will be mergedā¦ thanks
Was merged.
you must tryā¦ itās awesomeā¦ thanks
- platform: generic
still_image_url: https://maps.googleapis.com/maps/api/staticmap?center={{ states.binary_sensor.iss.attributes.lat }},{{ states.binary_sensor.iss.attributes.long }}&zoom=5&size=500x500&maptype=roadmap&markers=color:blue%7Clabel:P%7C{{ states.binary_sensor.iss.attributes.lat }},{{ states.binary_sensor.iss.attributes.long }}
limit_refetch_to_url_change: true
Thatās a nice one. I will add it to the docs. Thanks.
youār welcome
Is it possible to hide the sensor on the HA map but still show the location on the google maps side?
Yes, it is. Check the docsā¦
When I change the binar sensor to show_on_map:False or remove show_on_map completely I get this however if I change to true I get the correct screen but then am stuck with the icon on my HA maps.
Works fine on dev
with the sample from the docs.
camera:
- platform: generic
binary_sensor:
- platform: iss
show_on_map: False
I have my binary sensor yaml seperate from my camera yaml thus seperating the above config could this be the issue? Sorry to sound like a Noob!
I also got Map error on the top right with nothing.
Any solution?
I have the same issue where I get a google API error. I have an API key, and have the following in my camera.yaml file:
- platform: generic
still_image_url: https://maps.googleapis.com/maps/api/staticmap?center={{ states.binary_sensor.iss.attributes.lat }},{{ states.binary_sensor.iss.attributes.long }}&zoom=10&size=500x500&maptype=roadmap&markers=color:red%7Clabel:S%7C{{ states.binary_sensor.iss.attributes.lat }},{{ states.binary_sensor.iss.attributes.long }}&key=SHHDONTTELLANYONEMYAPIKEY
I also have Camera and binary sensors separated, but Iām not sure that would make a difference.
how you have generated the api key for google maps? I canāt found on https://console.cloud.google.com
once you are logged in, click āselect a projectā (top left) and then create a āNew project.ā
create the project, then select it from the drop down at the top of the previous page. Then you can select Enable APIās and Services (again at the top of the page) and enable the APIs you need.
