Intesis - clima device integration without cloud connector
hi,
i know it exist a cloud connector, but i want to control the device without cloud.
so i tested a little bit and developed a little powershell script, to control the device.
but i don’t know, how to put it in a “integration” to include it to home assistant.
It would be nice, if some one can help me or can take over this task.
##device: mh-ac-wifi-1
$climaip="172.16.218.152"
$prot="http"
$uri="$($prot)://$($climaip)/api.cgi"
$user="admin"
$password="admin"
$climaConfigJson=@"
        "Name":  "Power",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "1"
        "Name":  "Mode",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "2"
        "Name":  "LuefterGeschwindigkeit",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "4"
        "Name":  "Vane Up/Down Position",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "5"
        "Name":  "User Setpoint",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "9"
        "Name":  "Return Path Temperature",
        "RW":  "R",
        "Calc":  "10",
        "UID":  "10"
        "Name":  "Remote Disable",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "12"
        "Name":  "Laufzeit",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "13"
        "Name":  "Alarm Status",
        "RW":  "R",
        "Calc":  "0",
        "UID":  "14"
        "Name":  "Fehler Code",
        "RW":  "R",
        "Calc":  "0",
        "UID":  "15"
        "Name":  "Mindesttemperatur",
        "RW":  "R",
        "Calc":  "10",
        "UID":  "35"
        "Name":  "MaxTemperatur",
        "RW":  "R",
        "Calc":  "10",
        "UID":  "36"
        "Name":  "AussenTemperatur",
        "RW":  "R",
        "Calc":  "10",
        "UID":  "37"
        "Name":  "Maintenance time",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "181"
        "Name":  "Maintenance config",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "182"
        "Name":  "Maintenance Filter time",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "183"
        "Name":  "Maintenance Filter config",
        "RW":  "RW",
        "Calc":  "0",
        "UID":  "184"
$climainfos=(Invoke-RestMethod "http://172.16.218.152/js/data/data.json" )
function get_climaPostData{
    param(
        $command,
        $data
$r1 = New-Object PSCustomObject
$r1 | Add-Member -type NoteProperty -name command -Value $command
$r1 | Add-Member -type NoteProperty -name data -Value $data
    return ($r1 | ConvertTo-Json)
    # | % { [System.Text.RegularExpressions.Regex]::Unescape($_) } )
function Clima_Login {
param(
    $user,$pwd
    $r1 | Add-Member -type NoteProperty -name username -Value $user
    $r1 | Add-Member -type NoteProperty -name password -Value $pwd
    $data=get_climaPostData -command "login" -data  $r1
    $data= $data | ConvertFrom-Json | ConvertTo-Json
    try{
        $invoke=Invoke-RestMethod -Method post -Uri $uri -Body $data
    catch{
        $invokeerr="$_"
    if (!($invoke.data.id.sessionID) -or $invokeerr) {
        write-host "Error" -ForegroundColor Red
        write-host $invokeerr
        write-host $invoke
    return $invoke.data.id.sessionID
function Clima_getavailabledatapoints {
param(
    $sessionid
    $r1 | Add-Member -type NoteProperty -name sessionID -Value $sessionid
    $data=get_climaPostData -command "getavailabledatapoints" -data  $r1
    try{
    catch{
        $invokeerr="$_"
    if (!($invoke.data.dp.datapoints) -or $invokeerr) {
        write-host $invoke
    return $invoke.data.dp.datapoints
function Clima_All_getdatapointvalue {
param(
    $sessionid,
    $uid="all"
    $r1 | Add-Member -type NoteProperty -name uid -Value $uid
    $data=get_climaPostData -command "getdatapointvalue" -data  $r1
    try{
    catch{
        $invokeerr="$_"
    if (!($invoke.data.dpval) -or $invokeerr) {
        write-host $invoke
    return $invoke.data.dpval
function Clima_Set_Value {
param(
    $sessionid,
    $name,
    $val
    $config=$climaConfig |?{$_.name -like $name}
    if (!($config) -or ($config.RW -notlike "RW")) {
     Write-Host "Config Error or Name wrong" -ForegroundColor Red
     return
    $r1 | Add-Member -type NoteProperty -name uid -Value $config.uid
    $r1 | Add-Member -type NoteProperty -name value -Value $val
    $data=get_climaPostData -command "setdatapointvalue" -data  $r1
    $data=@"
          "command": "setdatapointvalue",
          "data": {
            "sessionID": "$($sessionid)",
            "uid": $($config.uid),
            "value": $val
    write-host $data
    try{
    catch{
        $invokeerr="$_"
    if (!($invoke.success) -or $invokeerr) {
        write-host $invoke
    return $data
$climaConfig=$climaConfigJson | ConvertFrom-Json
$sessionId=Clima_Login -user $user -pwd $password
if ($sessionid) {
$datapoints=Clima_getavailabledatapoints -sessionid $sessionId
$allvalues=Clima_All_getdatapointvalue -sessionid $sessionId
foreach($val in $allvalues) {
    $config=$climaConfig|?{$_.uid -eq $val.uid}
    $val | Add-Member -MemberType NoteProperty -Name "Name" -Value $config.name -Force
    $val | Add-Member -MemberType NoteProperty -Name "RW" -Value $config.rw -Force
    if ($config.calc -gt 0) {
        if ($config.calc -eq 10) {
            $val | Add-Member -MemberType NoteProperty -Name "value" -Value ([int]$val.value/10) -Force
#Clima_Set_Value -sessionid $sessionId -name "LuefterGeschwindigkeit" -val 4
#Aus:
#Clima_Set_Value -sessionid $sessionId -name "Power" -val 0
#an:
#Clima_Set_Value -sessionid $sessionId -name "Power" -val 1
$allvalues| select name,value
else{
    Write-Host "No Session ID" -ForegroundColor Red
best regards
Chris
It’s quite hard to read what you have shared. Try to publish all the code as code (see the buttons in the top of the edit dialog) and I’m sure you will increase the chance to have someone looking at your case.
Take a look at this:
