I’ve got the same Intesis MH-AC-WIFI-1 Card.
can someone do something with the local API ?
http://address/js/data/data.json
"api":{
"url":{
"getinfo" : "/js/api/getconfig.json",
"login" : "/js/api/login.json",
"logout" : "/js/api/logout.json",
"update_password" : "/js/api/update_password.json",
"getavailabledatapoints": "/js/api/getavailabledatapoints.json",
"getdatapointvalue" : "/js/api/getdatapointvalue.json",
"setdatapointvalue" : "/js/api/setdatapointvalue.json",
"getcurrentconfig" : "/js/api/getcurrentconfig.json",
"identify" : "/js/api/identify.json",
"wpsstart" : "/js/api/wpsstart.json",
"getaplist" : "/js/api/getaplist.json",
"setdefaults" : "/js/api/setdefaults.json",
"setconfig" : "/js/api/setconfig.json",
"reboot" : "/js/api/reboot.json",
"getavailableservices" : "/js/api/getavailableservices.json"
"error":{
"0":"Undefined error",
"1":"Login Required.",
"2":"Write Error",
"3":"Read Error",
"4":"Malformed Command",
"5":"Incorrect User name or password",
"6":"Current password is incorrect",
"7":"Out of range",
"8":"Invalid datapoint",
"9":"Internal error",
"10":"General error"
"info":{
"deviceModel":"Device Model",
"fwVersion":"Device Firmware Version",
"wlanFwVersion":"Wireless Firmware Version",
"sn":"Serial Number",
"wlanSTAMAC":"Device Client MAC Address",
"ssid":"Wireless Network SSID",
"wlanLNK":"Connection Status with Wireless Network",
"rssi":"Wireless Signal Strength",
"wlanAPMAC":"Device Access Point MAC Address",
"ownSSID":"Device Access Point SSID",
"tcpServerLNK":"Cloud Server Connection",
"acStatus":"Air Conditioner Communication Status",
"lastconfigdatetime":"Last Configuration",
"localdatetime":"Local Date Time"
"types":{
"int":0,
"enum":1,
"temp":2
"acStatus":{
"0":"Ok",
"1":"Indoor Unit Error",
"2":"Communication Error"
"lastError":{
"0":"No error",
"1":"Wrong SSID introduced in the last configuration attempt",
"2":"Unsuccessful connection with the Access Point or router, check the password or the security mode selected",
"3":"Wrong IP configuration introduced or Internet connection problem in your network",
"4":"Your Access Point might be a captive portal. This type of network is not supported",
"7":"WPS failed. Try it again or configure your device by using the automatic or manual mode"
"wifiConfig":{
"securityType": {
"0":"Open",
"1":"WEP",
"2":"WPA_PSK",
"3":"WPA2_PSK",
"4":"WPA_WPA2_PSK",
"5":"WPA2_Enterprise"
"levelText":{
"0":"Low",
"1":"Acceptable",
"2":"Good",
"3":"Very Good",
"4":"Excelent"
"signals":{
"uid":{
"1": ["On/Off", "TEXT_VALUES_ONOFF", ""],
"2": ["User Mode", "TEXT_VALUES_MODES", ""],
"4": ["Fan Speed", "TEXT_VALUES_FANSPEED", ""],
"5": ["Vane Up/Down Position", "TEXT_VALUES_VANES", ""],
"6": ["Vane Left/Right Position", "TEXT_VALUES_VANES", ""],
"9": ["User Setpoint", {}, "°C"],
"10": ["Return Path Temperature", {}, "°C"],
"12": ["Remote Disable", "TEXT_VALUES_REMOTE", ""],
"13": ["On Time", {}, "h"],
"14": ["Alarm Status", "TEXT_VALUES_ONOFF", ""],
"15": ["Error Code", {}, ""],
"34": ["Quiet Mode", "TEXT_VALUES_ONOFF", ""],
"35": ["Min Temperature Setpoint", {}, "°C"],
"36": ["Max Temperature Setpoint", {}, "°C"],
"37": ["Outdoor Temperature", {}, "°C"],
"60": ["Heat 8/10ºC", "TEXT_VALUES_ONOFF", ""],
"61": ["cfg Mode Map", {}, ""],
"62": ["cfg Mode Restrict", {}, ""],
"63": ["cfg Horizontal Vanes", {}, ""],
"64": ["cfg Vertical Vanes", {}, ""],
"65": ["cfg Quiet mode", {}, ""],
"66": ["cfg Confirmation On/Off", {}, ""],
"67": ["cfg Fan Map Speed", {}, ""],
"68": ["Instant Power Consumption", {}, "W"],
"69": ["Accumulated Power Consumption", {}, "Wh"],
"181": ["Maintenance time", {}, "h"],
"182": ["Maintenance config", {}, "h"],
"183": ["Maintenance Filter time", {}, "h"],
"184": ["Maintenance Filter config", {}, "h"]
"uidTextvalues":{
"TEXT_VALUES_ONOFF": {
"0":"Off",
"1":"On"
"TEXT_VALUES_MODES": {
"0":"Auto",
"1":"Heat",
"2":"Dry",
"3":"Fan",
"4":"Cool"
"TEXT_VALUES_FANSPEED": {
"0":"Auto",
"1":"Speed 1",
"2":"Speed 2",
"3":"Speed 3",
"4":"Speed 4",
"5":"Speed 5",
"6":"Speed 6",
"7":"Speed 7",
"8":"Speed 8",
"9":"Speed 9",
"10":"Speed 10"
"TEXT_VALUES_VANES": {
"0":"Auto",
"1":"Position 1",
"2":"Position 2",
"3":"Position 3",
"4":"Position 4",
"5":"Position 5",
"6":"Position 6",
"7":"Position 7",
"8":"Position 8",
"9":"Position 9",
"10":"Swing",
"11":"Swirl",
"12":"Wide"
"TEXT_VALUES_REMOTE": {
"0":"Remote Enabled",
"1":"Remote Disabled"
