Yes, thanks, that helped Now i have proper switch, but after switching on, it bounces back to off and then, on coordinator update, it bounces back to on. Do you update coordinator in async_turn_on() or async_turn_off() with return values from async_set_power() ?
I’m glad it helped. I spend lot of time on trial and error. It’s just glued together from pieces i found online. Problem is, that some things - for example entity attributes, can be defined in many ways and it seems, all are right
I will try to create cilimate entity for controling temperature and heating and then, i will wait for your properly written code
Does the decompiled code contain table of error codes?
ok, i figured out how to update coordinator using status returned from turn on or off methods
async def async_turn_off(self, **kwargs: Any) -> None:
"""Turn off switch"""
status = await self.spa.async_set_heater(False)
self.coordinator.async_set_updated_data(status)
Ok, climate entity was extremely easy, using all the knowledge from yesterday.
Does it make sense, to control “bubbles” here as fan?
<string name="e81_content">Make sure the spa is powered on and the wireless control panel is within range of the control base (5m / 16ft).</string>
<string name="e81_title">E81 - Transmission signal failure!</string>
<string name="e90_content">Check the filter cartridge and ensure nothing is clogging the circulation system.</string>
<string name="e90_title">E90 - Low or no water flow!</string>
<string name="e91_content">Add more salt and make sure the electrolytic cell cord is firmly plugged in.</string>
<string name="e91_title">E91 - Low salt level or no salt!</string>
<string name="e92_content">Partially drain the spa and refill with fresh water.</string>
<string name="e92_title">E92 - High salt level!</string>
<string name="e94_content">Add warm water to raise the spa temperature above 5ºC / 41ºF.</string>
<string name="e94_title">E94 -Water temperature too low!</string>
<string name="e95_content">Turn off the heater, check the filter cartridge and ensure nothing is clogging the circulation system.</string>
<string name="e95_title">E95 -Water temperature too high!</string>
<string name="e96_content">Turn off and unplug the spa. Check the filter cartridge and ensure nothing is clogging the circulation system, then restart the spa.</string>
<string name="e96_title">E96 - Control base system error!</string>
<string name="e97_content">Turn off and unplug the spa immediately. Contact Intex Service Center.</string>
<string name="e97_title">E97 - Heater dry-fire protection activated!</string>
<string name="e99_content">Turn off and unplug the spa immediately. Contact Intex Service Center.</string>
<string name="e99_title">E99 - Damaged water temperature sensor!</string>
I hope it helps
Thanks @CyrilP
We still have to find out how the errors are coded inside of the status response.
I’ll try and go on working on the integration today… @elkropac, you got so far!!!
Thanks, I implemented it !
I personally tend to consider bubbles as a specific switch.
If not, how to consider jets ?
have a look in DeviceSPAActivity
} else if ((parseInt < 182 || ((parseInt >= 190 && parseInt <= 197) || parseInt == 199)) && needShowErrorCode(appendZeroToStr(binaryString))) {
this.hasErrorCode = true;
TextView textView = this.mErrorCode;
StringBuilder sb = new StringBuilder();
sb.append("E");
int i = parseInt - 100;
sb.append(i);
textView.setText(sb.toString());
showErrorContent("E" + i);
Great ! But do some error detection please, i don’t know, what happens, if status
is not instance of IntexSpaStatus
- maybe do some method in your IntegrationIntexSpaEntity
class to handle errors and call it from all async_turn_on/off
methods?
I did not consider jets, i don’t have them . You are right, you cannot cram all functionality to enitity not to ment to be SPA
I went on with the integration, and am currently implementing the climate entity:
It’s working, and… it can be installed from HACS ! First, add the custom repository URL, as you won’t find it yet in the repositories known by HACS.
This is still Work In Progress. Namely, simultaneous requests lead to an exception (quite bad) and has to be investigated.
Thanks, i have installed it few minutes ago
status is an IntexSpaStatus, or an exception is raised.
So I did not implement error detection there, but we should assert that all errors eventually proceeds to an exception
Created an account to say thanks.
This stuff is awesome and works perfectly here.
Nice!
