To try Hass.io, can I install it on my Ubuntu server next to my current HA install (installed in virtual env). ?
Yes, but make sure that the port 8123 is not clame by other hass instance. If you want try it save the best way is inside a VM
Yes the system is a docker only construct. You can build local addons or use the appstore inside hass.io but it need to by a docker. On this way we can delivery ready to use application and it give high security between applications.
Having problem configuring SSH anyone got any ideas.
So Hass.io will only ever be able to run using Docker? Will Home Assistant continue to exist as a standalone version? I am running it in on FreeBSD (in a jail), and have no intention of moving over to docker.
Yes we stay on docker. I like FreeBSD with jails and have also work a long time with it, but it is not a docker with that functionality. Docker run on linux, mac osx, Windows prof and with linux layer also on freebsd. Jails run only on FreeBSD
The beta is for single only. But it is fix plane that Hass.IO support also snapshot/backups. If that feature inside, it should be easy to write a HA add-on that do that or maby it will be a core feature.
A real cluster is at the moment not possible. Mabye in future with some change on docker swarm it could be possible to run Hass.IO in that clustering. But there are no planes at the moment.
Just realised something, since all of hass.io is based on resinOS, i would love just the hability to run docker containers (based on resinOS images, to run on raspberry).
I noticed you are using FROM %%BASE_IMAGE%% in the dockerfile example for adons.
Resin.io offers a LOT of other base images : https://docs.resin.io/runtime/resin-base-images/ it would be a shame to not be able to use them too !
Example : resin/raspberry-pi3-alpine-node
Not sure if we can still use this : https://docs.resin.io/deployment/docker-templates/ to be able to write platform independant dockerfile.
FROM resin/%%RESIN_MACHINE_NAME%%-alpine-node
will download this : https://hub.docker.com/r/resin/raspberrypi2-alpine-node/
but âThis repository is obsolete.â
Also, one thing i did not understood : if i make a github repository, there is no point on having the dockerfile on dockerhub too ? (and no building process too, since thatâs to generate multiple images for each platform, right ?)
Plus what does the homeassistant/docker-build-env do ? i mean there is no source available ?
Started up a new fresh install of Hass.io. After first upstart i was able to see the frontpage at hassio.local:8123
I went in to Hass.io settings tab and there i saw some text below âInstalled Addonsâ.
I did shutdown the pi to add the âauthorized_keysâ file to be able to SSH into the pi.
At second upstart there is nothing below âInstalled Addonsâ.
How do i add addons?
And how do i change the timezone on the pi? there seem to be no raspi-configâŠ
And docker logs hassio_supervisor gives me a:
Error: No such container: hassio_supervisor
The Path to configuration.yaml: that shows in âinfoâ
Is a little confusingâŠ
i found the files here when i ssh with winscp:
We use resin base image for our addons. https://home-assistant.io/hassio/addon_testing/#local-run
We only support this 4 add-ons arch types. A maintainer of a hass.io repository need to prebuild all add-ons to docker hub, in this case we make a arch support and need only 4 docker image to support all platform instead to build 30 machine based image. So you can use our build script https://home-assistant.io/hassio/addon_publishing/
But at the end, you can use any stuff and push it to docker hub. With image setting inside config, we load it.
My âHass.ioâ Menu Button disappeared? Have i killed something?
docker ps shows all running.
Make sure you have hassio: component or discovery: component loaded.
Thanks, that was it. Tested some configuration where discovery was disabled.
Inserted hassio:
How small was too small?
8GB. Virtualbox VM for testing.
On time to update, you have 2 homeassistant docker. If the new docker is okay, we Switch to new homeassistant docker and remove the old. But for 30sec you have 2 homeassistant docker present on your system.
@pvizeli Hello, you said here : Release Notes
âLocal repository build now add-on local if no image is setâ
Does it mean that using Docker Hub is not mandatory anymore ?
And that it will build the Dockerfile located in the add-on folder ? : https://home-assistant.io/hassio/addon_config/
