Dear Tom,
Before getting started, the question is getting started with WHAT???
WHAT is Home Assistant, and what is inside the box… how does the Device Communication take place and when, between the HA Device Signal Memory / and the Physical Devices… What triggers the logic execurion based on changing Sensors values and that new values are communicated to actuators or light bulbs or relays…
It is about understanding how HA internally works versus an Industrial Controller, PLC as e.g. CodeSys… that also can execute on a RPI platform…
I asked ChatGPT:
What makes Home Assistant communicate with its devices, what events trigger the update from device to HA and viseversa
ChatGPT
Home Assistant (HA) communicates with devices using integrations, protocols, and event-based mechanisms. The specific methods depend on the type of device and the protocol used. Below is an explanation of how communication occurs and what events trigger updates between devices and HA:
1. Communication Mechanisms
Home Assistant communicates with devices through various methods:
- Local API Calls: Direct communication with devices via APIs provided by manufacturers (e.g., smart lights, thermostats).
- Cloud APIs: Some integrations rely on the cloud for device interaction (e.g., Tuya, Google Assistant).
- Protocols: Support for communication protocols like Zigbee, Z-Wave, MQTT, Bluetooth, and Wi-Fi.
- Custom Integrations: Device manufacturers or the community may provide specific integrations for proprietary devices.
2. Events Triggering Updates
Communication between devices and HA is event-driven, which means updates occur when certain actions or conditions are met.
a. Device-to-Home Assistant Updates
Devices send updates to HA when:
- State Change: A device changes its state (e.g., a light is turned on, a sensor detects motion).
- Periodic Reporting: Some devices report their status periodically (e.g., temperature sensors sending data every minute).
- Poll Requests: HA polls the device for its status at regular intervals (used when devices don’t support event-driven updates).
- Push Notifications: Devices with push capability send updates in real-time to HA when something changes (e.g., MQTT publishes messages).
b. Home Assistant-to-Device Updates
HA sends updates to devices when:
- User Interaction: A user interacts with the HA interface, such as toggling a light switch or adjusting a thermostat.
- Automations and Scripts: Predefined automations trigger actions (e.g., turning off all lights at a specific time).
- Event Triggers: External events (e.g., sunset, geolocation changes, weather updates) trigger actions in HA.
3. Protocol-Specific Details
Protocol |
Communication Details |
Zigbee |
- Devices communicate through a Zigbee hub. |
- Updates are event-driven or periodic, depending on configuration.|
|Z-Wave|- Uses mesh networking for device communication.
- Events are triggered by state changes or polling.|
|MQTT|- Devices publish messages to a broker.
- HA subscribes to these messages for updates.
- Real-time or periodic updates.|
|Wi-Fi|- Devices communicate directly over the network.
- Updates occur via APIs or cloud services.|
|Bluetooth|- Devices use Bluetooth to send updates.
- Limited range; often used for sensors or trackers.|
4. Customization and Configurations
- Polling Intervals: HA allows users to configure polling intervals for devices that don’t push updates. This ensures data is refreshed regularly.
- Event Triggers: Users can define custom event triggers (e.g., “if temperature > 30°C, send an update”).
- Automations: Users can create complex rules that dictate how devices should behave based on events, conditions, and triggers.
5. Ensuring Timely Updates
- Optimize Protocols: Use protocols like MQTT, Zigbee, or Z-Wave, which support real-time updates.
- Network Reliability: Ensure devices and HA are on a reliable network to avoid delays or missed updates.
- Monitor Logs: HA’s logging tools help diagnose communication issues with devices.
- Use Add-ons: Add-ons like Zigbee2MQTT or Z-Wave JS improve integration with respective protocols.
Summary
Home Assistant communicates with devices through a combination of real-time event-driven updates, periodic reporting, and user or automation-triggered actions. The choice of protocol and integration determines how efficiently these updates occur. Proper configuration and optimization ensure a responsive and seamless smart home experience.
NEEDED:
I need a thorough discussion of the entire signal flow from HA Sensors to HA memory, to HA Logics, or Calculations, back to HA memory and then to HA Actuator… using different Control Software as Native HA logics, Node-RED, Python, PyScripts… etc…
