Invalid Add-on Repository
Has anyone experienced the above message when attempting to add any custom repository? I am new to Home Assistant and didn’t have much setup in terms of devices and integrations so I was able to blast my config away and start over (tried both SD card and SSD installs) yet the issue persists.
Can successfully SSH to my install and ping out to the internet, and to github.com.
“ha dns info” returns 192.168.0.1 as my DNS server (provided by DHCP from my RT-AC68U running merlin FW)
1-09-27 09:49:10 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/thomasmauerer/hassio-addons/tree/master/samba-backup repository
21-09-27 09:49:11 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/thomasmauerer/hassio-addons/tree/master/samba-backup repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/thomasmauerer/hassio-addons/tree/master/samba-backup /data/addons/git/da55f798
  stderr: 'Cloning into '/data/addons/git/da55f798'...
fatal: repository 'https://github.com/thomasmauerer/hassio-addons/tree/master/samba-backup/' not found
21-09-27 09:49:11 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / da55f798
21-09-27 09:49:11 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/thomasmauerer/hassio-addons/tree/master/samba-backup
21-09-27 09:49:11 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-09-27 09:49:11 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-09-27 09:49:12 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 0 new - 0 remove
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: da55f798
21-09-27 09:49:12 INFO (MainThread) [supervisor.store.git] Removing custom add-on repository https://github.com/thomasmauerer/hassio-addons/tree/master/samba-backup
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-09-27 09:49:12 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
System Health
version: core-2021.9.7
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.17-v8
arch: aarch64
timezone: Europe/Dublin
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 6.4
update_channel: stable
supervisor_version: supervisor-2021.09.0
docker_version: 20.10.7
disk_total: 109.3 GB
disk_used: 2.8 GB
healthy: true
supported: true
board: rpi4-64
supervisor_api: ok
version_api: ok
installed_addons: Visual Studio Code (3.6.2)
dashboards: 1
resources: 0
mode: auto-gen
Url to repository is wrong, shorten it to
And you can go ahead
thank you very much man!! Worked.
Im getting the same error when i enter this URL. Is there something changed?
suspect a typo, it added fine here just now:
Same error here. Copy pasted the URL from the site.
