dailed to load components after upgrade …
Setup failed for ios: Could not set up all dependencies.
1:17 PM setup.py (ERROR)
Unable to set up dependencies of ios. Setup failed for dependencies: device_tracker
Setup failed for fan: Could not set up all dependencies.
Unable to set up dependencies of fan. Setup failed for dependencies: group
Setup failed for cover: Could not set up all dependencies.
Unable to set up dependencies of cover. Setup failed for dependencies: group
Setup failed for switch: Could not set up all dependencies.
Unable to set up dependencies of switch. Setup failed for dependencies: group
Setup failed for script: Could not set up all dependencies.
Unable to set up dependencies of script. Setup failed for dependencies: group
Setup failed for device_tracker: Could not set up all dependencies.
Unable to set up dependencies of device_tracker. Setup failed for dependencies: group
Setup failed for light: Could not set up all dependencies.
Unable to set up dependencies of light. Setup failed for dependencies: group
Setup failed for automation: Could not set up all dependencies.
Unable to set up dependencies of automation. Setup failed for dependencies: group
Can’t retrieve weather data from Yahoo!
1:17 PM components/sensor/yweather.py (CRITICAL)
Fetch no weather data Yahoo!
1:17 PM components/sensor/yweather.py (ERROR)
Setup failed for group: Invalid config.
Invalid config for [group]: Entity ID sensor._battery_level is an invalid entity id for dictionary value @ data[‘group’][‘dev_phones’][‘entities’]. Got [‘sensor.iphone5s_battery_level’, ‘sensor.iphone5s_battery_state’, ‘sensor._battery_level’, ‘sensor._battery_state’, ‘sensor.home_iphone_5s_battery_level’, ‘sensor.home_iphone_5s_battery_state’, ‘sensor.iphone_nino_battery_level’, ‘sensor.iphone_nino_battery_state’]. (See /config/configuration.yaml, line 591). Please check the docs at Group - Home Assistant
1:17 PM config.py (ERROR)
Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See /config/configuration.yaml, line 590). Please check the docs at Automation - Home Assistant
ress the button to load the full Home Assistant log.
2019-01-24 13:17:37 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don’t require it, remove the ‘api_password’ from your http config. 2019-01-24 13:17:42 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See /config/configuration.yaml, line 590). Please check the docs at Automation - Home Assistant 2019-01-24 13:17:46 ERROR (MainThread) [homeassistant.config] Invalid config for [group]: Entity ID sensor._battery_level is an invalid entity id for dictionary value @ data[‘group’][‘dev_phones’][‘entities’]. Got [‘sensor.iphone5s_battery_level’, ‘sensor.iphone5s_battery_state’, ‘sensor._battery_level’, ‘sensor._battery_state’, ‘sensor.home_iphone_5s_battery_level’, ‘sensor.home_iphone_5s_battery_state’, ‘sensor.iphone_nino_battery_level’, ‘sensor.iphone_nino_battery_state’]. (See /config/configuration.yaml, line 591). Please check the docs at Group - Home Assistant 2019-01-24 13:17:46 ERROR (MainThread) [homeassistant.setup] Setup failed for group: Invalid config. 2019-01-24 13:17:48 ERROR (SyncWorker_18) [yahooweather] Fetch no weather data Yahoo! 2019-01-24 13:17:48 CRITICAL (SyncWorker_18) [homeassistant.components.sensor.yweather] Can’t retrieve weather data from Yahoo! 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of automation. Setup failed for dependencies: group 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Setup failed for automation: Could not set up all dependencies. 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of light. Setup failed for dependencies: group 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Setup failed for light: Could not set up all dependencies. 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of device_tracker. Setup failed for dependencies: group 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Setup failed for device_tracker: Could not set up all dependencies. 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of script. Setup failed for dependencies: group 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Could not set up all dependencies. 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of switch. Setup failed for dependencies: group 2019-01-24 13:17:48 ERROR (MainThread) [homeassistant.setup] Setup failed for switch: Could not set up all dependencies. 2019-01-24 13:17:49 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cover. Setup failed for dependencies: group 2019-01-24 13:17:49 ERROR (MainThread) [homeassistant.setup] Setup failed for cover: Could not set up all dependencies. 2019-01-24 13:17:49 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of fan. Setup failed for dependencies: group 2019-01-24 13:17:49 ERROR (MainThread) [homeassistant.setup] Setup failed for fan: Could not set up all dependencies. 2019-01-24 13:17:50 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ios. Setup failed for dependencies: device_tracker 2019-01-24 13:17:50 ERROR (MainThread) [homeassistant.setup] Setup failed for ios: Could not set up all dependencies.
