My HA server was off for an extended period while I was moving. After setting it back up and updating everything, I now get an invalid config error for Node-Red. I’m not sure if it was a HA update, Node-Red update, or both that cause the issue.
I have two switch nodes that appear to no longer be working, although I’m not sure if that is a cause or a symptom of the invalid config.
Where should I start to troubleshoot this?
Than You,
Joshua
