Team
I have 5000 lines in Automation.yaml and have had this error up for some time. I went though all lines to check that the formating for Platform part is correct. Any idea what could be the issue?
line 18 is this in configuration.yaml
Team
It seems to be implying that the second trigger (i.e., index 1, since the list of triggers is zero-based) of one of the automations is missing the platform
key. Could it be a typo (i.e., misspelled platform)?
thank you sir for your response and help pointing me to the right direction.
I have installed Studio Code Server ( been using File Editor ) and the addon it selft found the error.
had missing Condition segment in one of the automations. Problem fixed!
I have the same sort of error
Automation with alias 'Radiator Schedule' could not be validated and has been disabled: required key not provided @ data['condition'][1]['device_id']. Got None
Automation with alias 'Radiator Schedule' could not be validated and has been disabled: extra keys not allowed @ data['condition'][1]['domain']. Got 'binary_sensor' extra keys not allowed @ data['condition'][1]['type']. Got 'is_not_open' required key not provided @ data['condition'][1]['state']. Got None`
This is my code
- alias: Radiator Schedule
description: "Set radiators to schedule"
- entity_id: person.xxxxx
platform: state
to: home
- entity_id: person.xxxxxx
platform: state
to: home
condition:
- condition: time
after: "07:00:00"
before: "23:00:00"
- condition: device
type: is_not_open
entity_id: binary_sensor.window_door_sensor
domain: binary_sensor
data: {}
service: script.radiatorschedule
When I inspect window_door_sensor
, I get
"on": true
temperature: 18
device_class: door
friendly_name: Window / Door Sensor
icon: mdi:lock
Can anyone help me identify the error and help fix the code?
Check your automation condition directly in the UI editor. The device id is missing. Create a example device condition and compare the code. Example:
condition: device
type: is_off
device_id: c5c01f5772f5bfbad64f28bd509b50bb
entity_id: 37e41a6b2d3fdf1f866f0a95253fffd0
domain: light
I changed the code to
- platform: state
entity_id:
- person.xxxxx
- person.xxxxxxx
to: "home"
condition:
- condition: time
after: "07:00:00"
before: "23:00:00"
- condition: state
state: 'off'
- service: script.turn_on
entity_id: script.radiatorschedule
and now the errors are gone.
