Invalid config for [automation]: (See /config/configuration.yaml, line 51)
I´m getting the Error “Invalid config for [automation]: (See /config/configuration.yaml, line 51).”
But i don´t know how can i fix this :frowning:
What´s wrong???
Screenshot 2021-01-11 085738
Check your automation.yaml file?
I did not found an Error there…
- alias: Air Purifier mode change
    entity_id: input_select.xiaomi_airpurifier_mode
    platform: state
    service: fan.set_speed
    data_template:
      entity_id: fan.xiaomi_miio_device
      speed: '{{ states.input_select.xiaomi_airpurifier_mode.state }}'
- alias: Air Purifier mode changed
    platform: state
  condition:
    condition: and
    conditions:
    - condition: template
      value_template: '{{ (state_attr(''fan.xiaomi_miio_device'', ''speed'') | string)
        != (states(''input_select.xiaomi_airpurifier_mode'') | string) }}'
    service: input_select.select_option
    data_template:
      option: '{{ states.fan.xiaomi_miio_device.attributes.speed }}'
- alias: Air Purifier favorite level change
    entity_id: input_number.xiaomi_airpurifier_favorite_level
    platform: state
    service: xiaomi_miio.fan_set_favorite_level
    data_template:
      level: '{{ states.input_number.xiaomi_airpurifier_favorite_level.state | int
- alias: Air Purifier favorite level changed
    platform: state
  condition:
    condition: and
    conditions:
      value_template: '{{ (state_attr(''fan.xiaomi_miio_device'', ''favorite_level'')
        | int) != (states(''input_number.xiaomi_airpurifier_favorite_level'') | int)
    service: input_number.set_value
    data_template:
      value: '{{ states.fan.xiaomi_miio_device.attributes.favorite_level }}'
- alias: Air Purifier mode change Werkstatt
    entity_id: input_select.xiaomi_airpurifier_wohnzimmer_mode
    platform: state
    data_template:
      entity_id: fan.xiaomi_air_purifier_2h_wohnzimmer
      speed: '{{ states.input_select.xiaomi_airpurifier_wohnzimmer_mode.state }}'
- alias: Air Purifier mode changed Werkstatt
    platform: state
  condition:
    condition: and
    conditions:
      value_template: '{{ (state_attr(''fan.xiaomi_air_purifier_2h_wohnzimmer'', ''speed'')
        | string) != (states(''input_select.xiaomi_airpurifier_wohnzimmer_mode'')
        | string) }}'
    data_template:
      option: '{{ states.fan.xiaomi_air_purifier_2h_wohnzimmer.attributes.speed }}'
- alias: Air Purifier favorite level change Werkstatt
    entity_id: input_number.xiaomi_airpurifier_wohnzimmer_favorite_level
    platform: state
    data_template:
      level: '{{ states.input_number.xiaomi_airpurifier_wohnzimmer_favorite_level.state
        | int }}'
- alias: Air Purifier favorite level changed Werkstatt
    platform: state
  condition:
    condition: and
    conditions:
      value_template: '{{ (state_attr(''fan.xiaomi_air_purifier_2h_wohnzimmer'', ''favorite_level'')
        | int) != (states(''input_number.xiaomi_airpurifier_wohnzimmer_favorite_level'')
        | int) }}'
    data_template:
      value: '{{ states.fan.xiaomi_air_purifier_2h_wohnzimmer.attributes.favorite_level
- id: '1583158555692'
  alias: mikepc abends aus
  description: ''
  - below: 70
    device_id: 7a490fe5e9b44db3a4e3fe9e2f623420
    domain: sensor
    entity_id: sensor.mikepc_sw_energy_power
    for:
      hours: 0
      minutes: 0
      seconds: 30
    platform: device
    type: power
  condition: []
  - device_id: 7a490fe5e9b44db3a4e3fe9e2f623420
    domain: switch
    entity_id: switch.mikepc_sw
    type: turn_off
  - type: turn_off
    device_id: 36bea4e6fe4011eab40c4390d17adf9e
    entity_id: switch.switch_cutter
    domain: switch
  mode: single
- id: '1583222366012'
  alias: microsoldering abends aus
  description: ''
  - platform: time
    at: '22:00'
  condition: []
  - device_id: 76ee93a7d9314384acfeb838c5d3da5b
    domain: switch
    entity_id: switch.microsoldering
    type: turn_off
  - type: turn_off
    domain: switch
  mode: single
- id: '1591215175480'
  alias: hassio backup
  description: ''
  - at: '23:00:00'
    platform: time
  condition: []
  - data:
      addon: 15d21743_samba_backup
    service: hassio.addon_start
- id: '1591686748490'
  alias: Purge Database
  description: ''
  - at: 03:00:00
    platform: time
  condition: []
  - data:
      keep_days: 5
    service: recorder.purge
- id: '1591974441272'
  alias: Klima abends aus
  description: ''
  - at: '21:00:00'
    platform: time
  condition: []
  - device_id: fb3c02813130406f866cff4544a6d9e2
    domain: climate
    entity_id: climate.daikinap48491
    type: set_hvac_mode
    hvac_mode: 'off'
  mode: single
- id: '1594921037770'
  alias: kasse an
  description: ''
  - above: 10
    device_id: 03457b7df4204bdb8d0545fd42c0765c
    domain: sensor
    entity_id: sensor.ds218_sw_energy_power
    platform: device
    type: power
  condition: []
  - device_id: 3df967bb2d704ecc83a592e0d7079cd8
    domain: switch
    entity_id: switch.switch_kasse_slave
    type: turn_on
    domain: switch
    entity_id: switch.switch_kasse_slave_2
    type: turn_on
- id: '1594921079922'
  alias: kasse aus
  description: ''
  - below: 9
    domain: sensor
    for:
      hours: 0
      minutes: 0
      seconds: 0
    platform: device
    type: power
  condition: []
    domain: switch
    type: turn_off
    domain: switch
    type: turn_off
- id: '1599470171203'
  alias: wireguard neustart
  description: ''
  - entity_id: input_boolean.wireguard_neustart
    platform: state
    to: 'on'
  condition: []
  - device_id: 914bf8b3c0364a6b97e61c1fb8a8ba30
    domain: switch
    entity_id: switch.wireguard_sw
    type: turn_off
  - delay: 00:00:10
    domain: switch
    type: turn_on
  - data: {}
    service: homeassistant.turn_off
  mode: single
- id: '1600337649060'
  alias: klima aus
  description: ''
  - device_id: f6dad804ca60483f9dcb14c9a83de9a0
    domain: zha
    platform: device
    subtype: button_6
    type: remote_button_alt_short_press
  condition: []
    domain: climate
    hvac_mode: 'off'
    type: set_hvac_mode
  mode: single
- id: '1600337700604'
  alias: klima an
  description: ''
  - device_id: dc61b21355547ef9c842f5385d65eb56
    domain: zha
    platform: device
    subtype: button_5
  condition: []
    domain: climate
    hvac_mode: heat
    type: set_hvac_mode
  mode: single
- id: '1602659449126'
  alias: wassersensor mail
  description: ''
  - type: moist
    platform: device
    device_id: bdaf014089cd10880cbccce121310572
    entity_id: binary_sensor.lumi_lumi_sensor_wleak_aq1_ias_zone
    domain: binary_sensor
    for:
      hours: 0
      minutes: 0
      seconds: 10
  condition: []
  - service: notify.mailfreiburg
      title: Wassersensor Freiburg
      message: Boden ist nass
  mode: single
- id: '1607415532073'
  alias: klima aus
  description: ''
    domain: zha
    platform: device
    subtype: button_6
  condition: []
    domain: climate
    type: set_hvac_mode
    hvac_mode: 'off'
  mode: single
- id: '1607415721977'
  alias: pc´s an
  description: ''
  - device_id: 8fdc12b7e82d3920f7ef4e6f282d85b5
    domain: zha
    platform: device
    subtype: button_1
  condition: []
  - type: turn_on
    domain: switch
  - delay: 00:00:10
  - type: turn_on
    domain: switch
  mode: single
- id: '1608316576766'
  alias: klima an
  description: ''
    domain: zha
    platform: device
    subtype: button_5
  condition: []
    domain: climate
    type: set_hvac_mode
    hvac_mode: heat
  mode: single
- id: '1608317875998'
  alias: klima aus
  description: ''
    domain: zha
    platform: device
    subtype: button_6
  condition: []
    domain: climate
    type: set_hvac_mode
    hvac_mode: 'off'
  mode: single
- id: '1609406114001'
  alias: kundenzähler
  description: ''
  - platform: state
    entity_id: binary_sensor.cam_aussen_line_crossing
    to: 'on'
  condition: []
  - service: counter.increment
    data: {}
    entity_id: counter.kunden
  mode: single
- id: '1609758857372'
  alias: Kundezähler reset
  description: ''
  - platform: time
    at: 00:00:01
  condition: []
  - service: counter.reset
    data: {}
  mode: single
Did it work before? Have you changed anything?
It could be as simple as indents.
You could also try and comment out everything first and start uncommenting bit by bit to find out the part that gives you issues.
OK, i will try with comment out.
Btw: How can i comment out all?
That depends on the editor you use. If you do not know or you use the editor add-on, I would recommend renaming your original file automation.yaml and creating a new one and start moving pieces from one to another.
I could use notepad++
Or which Editor do you prefer?
i know in HTML i can use <!-- and --!>
I use Visual Studio Code. its easy and I have installed the Samba add-on so I can open the file directly without copying or moving first.
Ok,
i can use it too.
But how can i comment a block in Visual Studio Code?
Mark all lines and Ctrl K and then C. it will add a # in front of each line.
and to uncomment the same?
line by line… I am not aware of a mass uncomment.
If you have a lot of text, I would go with the new file approach.
Thanks.
Will try it :slight_smile:
Found the Problem.
Thanks again for your Help!
just out of curiosity, what was it?
a double Entry
To uncomment you can use CTRL + K, U
You learn something new every day!
